Browse Forums Windows & Doors 1 Jun 24, 2023 9:59 pm Hi all, I took these photos when visiting my new townhouse recently and noticed that along the bottom of these window frames it looks uneven/wavy, with excessive material and there’s even a small gap (see close up). Apologies for not knowing the proper terms to describe the issue but I hope the photos show what I mean. My pre-settlement inspection is coming up, should I raise this issue as a defect? Any thoughts are appreciated Close upLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Is this a defect in my window frame? 2Jul 10, 2023 3:55 pm Hi , I am not a pro builder but that looks rather scrappy to me, I would be adding that to your list ...of fixer ups... Even though the deadlines are set, in reality they tell me you are covered under builder's warranty, depending on your contract... Re: Is this a defect in my window frame? 3Jul 10, 2023 4:08 pm The way I see it, you should raise anything you aren't sure of in your inspection, they'll either note it down to be rectified or they will provide a reason why it is the way it is. I'm sure other more knowledgeable people on the forum might be able to provide a "correct/incorrect" to this particular issue, but my advice is more broad in raising anything you aren't sure of in the inspection. Best of luck. Re: Is this a defect in my window frame? 4Jul 13, 2023 3:03 pm Sorry, I have replied to this twice and my reply has disappeared again. "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Is this a defect in my window frame? 5Jul 13, 2023 3:32 pm MsMish Hi all, I took these photos when visiting my new townhouse recently and noticed that along the bottom of these window frames it looks uneven/wavy, with excessive material and there’s even a small gap (see close up). Apologies for not knowing the proper terms to describe the issue but I hope the photos show what I mean. My pre-settlement inspection is coming up, should I raise this issue as a defect? Any thoughts are appreciated Close upLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Testing reply. Re: Is this a defect in my window frame? 6Jul 14, 2023 1:54 pm Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I tried the same jpg and it would not show. I tried a second one and it didn't show either. So I tried this old one of mine... Must be something wrong with the files, yet they insert fine into Word. "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Is this a defect in my window frame? 7Jul 14, 2023 2:05 pm Apologies to all for hijacking this thread. Ed, can you please email across the files to myself so may investigate. Cheers. Building Standards; Getting It Right! There doesn't look to be any rebate in the slab to prevent water from scooting under the window. AS4654 is the Australian standard to look at/refer to. They have… 1 10808 you need to understand the breakdown of warranties. 90 warranty is considered as minor defects rectification period where as the longer ones are more major/structural… 1 5672 DIY, Home Maintenance & Repair The intent of that sort of clause is being misaaplied. its suposed to be used to avoid paying out for things liek when you decided to do a reno yourself and the… 3 6274 |
