Browse Forums Building Standards; Getting It Right! Re: Wall cracks, building footpath as per CSIRO BTF18 28Feb 01, 2022 8:24 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Wall cracks, building footpath as per CSIRO BTF18 34Jan 07, 2023 5:47 pm This is an option rather than a agi pipe but if you don't want to connected it to the storm water system then where ever it discharges (where the plastic sub surface channel ends) water will collect there and it could become very wet and soft so it should be away from any structures and not discharging into neighbouring properties. It will really depend on how your block slopes, block size, soil type etc. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Wall cracks, building footpath as per CSIRO BTF18 35Jan 07, 2023 5:55 pm If you want to use an agi pipe then it will have the same effect and create excessive water where ever it slopes to and ends. Normally they are connected to a pit which then transfer the water into the stormwater system which goes to a legal point of discharge. Re: Wall cracks, building footpath as per CSIRO BTF18 36Jan 07, 2023 6:05 pm groundzero This is an option rather than a agi pipe but if you don't want to connected it to the storm water system then where ever it discharges (where the plastic sub surface channel ends) water will collect there and it could become very wet and soft so it should be away from any structures and not discharging into neighbouring properties. It will really depend on how your block slopes, block size, soil type etc. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Yes, that's what we're concerned about - the water pooling at the end of the plastic, and the ground in that area becoming very soft/damp. We have H2 clay. We are on a couple of acres. The land slopes from the West to the East, so we get all of the surface water from our neighbour on the West. We get the most water on the West side of the house. On the other sides, the surface water has a nice fall away from the house. Installing an agi pipe all the way around the perimeter and then connecting it to the stormwater seems like a big (and expensive) task. We would like to avoid it if we can. But I can see how creating a fall for the first metre around the house (like the builder advises) is only likely to create a further problem. Re: Wall cracks, building footpath as per CSIRO BTF18 37Jan 07, 2023 6:07 pm groundzero If you want to use an agi pipe then it will have the same effect and create excessive water where ever it slopes to and ends. Normally they are connected to a pit which then transfer the water into the stormwater system which goes to a legal point of discharge. This is a good option to consider - thank you. Re: Wall cracks, building footpath as per CSIRO BTF18 38Jan 07, 2023 6:12 pm Do you know how deep the clays on the west side? Re: Wall cracks, building footpath as per CSIRO BTF18 39Jan 07, 2023 6:16 pm If you post photos that may help get a better idea of what is going on Re: Wall cracks, building footpath as per CSIRO BTF18 40Jan 07, 2023 6:16 pm groundzero Do you know how deep the clays on the west side? As in west suburbs of Melbourne? Deeper than you care to know lol Dark matter scientist, can breathe underwater, mind reader and can freeze matter just by willing it. Trust me, its in my sig. Hi all I am looking to run a water line under my concrete footpath which is directly next to my home, was seeing if this is possible without cutting the entire section… 0 20760 It sounds like you have a crack in your garage where the wall meets the ceiling, along the shadow line on the… 0 17886 Do I need to concern about this pattern of crack? Is this crack showing some signs of bigger problems? Thanks for any suggestions! 1 2171 |
