Browse Forums Old Home Restoration / Renovation Re: Adding void in renovation 2Dec 20, 2022 9:37 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Adding void in renovation 4Dec 20, 2022 10:18 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Adding void in renovation 6Dec 21, 2022 8:45 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Adding void in renovation 9Dec 21, 2022 2:19 pm Noname Neosdad I'll post up some pics shortly. I'm generally confused on what the steps are. Instead of starting off with an engineer, wouldn't I need to do concept designs of what I want before I get advice from an engineer if it's possible and then the engineer would work with the designer on amendments or to design it in a way that meets my requirements and budget? It sounds strange if a designer or engineer is strictly prescribing the end result. Somewhat of a balance between art and engineering no. an an engineer will tell you whats possible and what works would be required - this translates easily to costs. If you get somone to draw it up first, there no guarantee the engineering can be achieved. Usually it can, but often at greater cost than if you engaged an engineer to work it out and going from there. You have to look at it from a practical perspective rather than from an aspirational perspective, unless of course money is no object, then go the drawing route and get exactly what you want. Thanks! So I guess get an engineer on site and tell them what I want and they come back with what's possible/work required and expected costs? Will they also provide specifics on any support beams so that a builder can follow and build to spec? And do I simply look for the services of a structural engineer for this work? Re: Adding void in renovation 10Dec 21, 2022 2:21 pm Neosdad Noname Neosdad I'll post up some pics shortly. I'm generally confused on what the steps are. Instead of starting off with an engineer, wouldn't I need to do concept designs of what I want before I get advice from an engineer if it's possible and then the engineer would work with the designer on amendments or to design it in a way that meets my requirements and budget? It sounds strange if a designer or engineer is strictly prescribing the end result. Somewhat of a balance between art and engineering no. an an engineer will tell you whats possible and what works would be required - this translates easily to costs. If you get somone to draw it up first, there no guarantee the engineering can be achieved. Usually it can, but often at greater cost than if you engaged an engineer to work it out and going from there. You have to look at it from a practical perspective rather than from an aspirational perspective, unless of course money is no object, then go the drawing route and get exactly what you want. Thanks! So I guess get an engineer on site and tell them what I want and they come back with what's possible/work required and expected costs? Will they also provide specifics on any support beams so that a builder can follow and build to spec? And do I simply look for the services of a structural engineer for this work? yes yes and yes. Thats the idea. if you are in NSW, reach out to @ashington Homes for a possible contact. He seems to know quite a few good sorts in various parts of the building game. Dark matter scientist, can breathe underwater, mind reader and can freeze matter just by willing it. Trust me, its in my sig. Adding void in renovation 11Dec 22, 2022 7:18 pm StructuralBIMGuy @pulse So you're advocating cutting a 6m2 void in a suspended concrete slab without top steel? Chris, he didn’t mention it was a suspended slab. I assumed it was timber and covered by AS1684. Your comment is not constructive. You’ve misrepresented my advice to make it sound stupid. This is the strawman fallacy. As if a poster here is going to use a demo saw to cut a hole in a suspended slab. You should really try to post in a helpful and constructive way and not belittle the contributions of others. It will make you and all those you interact with happier and makes for a better forum. Cheers Pulse Re: Adding void in renovation 12Dec 22, 2022 7:38 pm Hey pulse here in WA the majority of 60 yo Double brick Houses have suspended Concrete structural slabs to AS3600 Yes, engineers here modify and cut up suspended concrete slabs and council requires engineering details and certification for all structural changes. be it AS1720 structural timber (floors). AS3600 structural Concrete, As 4100 Structural Steel AS1684 will not pass the certified structural test.. adding voids is not a cookie cutter standard change Also if posters fail to put up additional information then it would be remiss of me as an engineer not to expect worse/assume case scenarios. OT Ask the council builder surveyor the correct process and post back Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Adding void in renovation 13Dec 23, 2022 9:09 am Pulse Your comment is not constructive. You’ve misrepresented my advice to make it sound stupid. This is the strawman fallacy. None of his comments are. and he is a narcissist, so what do you expect? Just keep calling him out for being a douchebag and maybe one day he'll get it. Dark matter scientist, can breathe underwater, mind reader and can freeze matter just by willing it. Trust me, its in my sig. Re: Adding void in renovation 14Dec 23, 2022 9:15 am The only smartest thing you have ever said here was consult an engineer ..go figure Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Adding void in renovation 15Dec 23, 2022 9:23 am StructuralBIMGuy The only smartest thing you have ever said here was consult an engineer ..go figure i wish i could point to something smart you've said. Go figure indeed. HTH Dark matter scientist, can breathe underwater, mind reader and can freeze matter just by willing it. Trust me, its in my sig. Not sure if that works? I was told the issue is the headspace clearance requirement on step 4. My builder is proposing shifting the beam 310mm towards the kitchen...I'm… 2 2937 To me, that's what it looks like: poor backfilling and/or compaction. The width is about 1000mm maybe. That conduit in the photo is for the NBN. The water is about… 4 8515 |
