Trying to rule out Mr Fluffy and not sure what kind of insulation this is:
Browse Forums Heating, Cooling & Insulation Re: Roof Insulation Material Check 2Nov 03, 2022 3:17 pm Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Roof Insulation Material Check 4Nov 03, 2022 3:47 pm It's usually limited to the thickness of the joists and it compacts over time, so yes it's insulating properties are pretty poor compared to thick batts. Plus it's very messy if you need to work in the roof space. It's also a pain to remove. The easiest way to remove it is a truck mounted industrial vacuum. You vac out the roof space and start again. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Roof Insulation Material Check 5Nov 03, 2022 4:30 pm chippy It's usually limited to the thickness of the joists and it compacts over time, so yes it's insulating properties are pretty poor compared to thick batts. Plus it's very messy if you need to work in the roof space. It's also a pain to remove. The easiest way to remove it is a truck mounted industrial vacuum. You vac out the roof space and start again. Thanks for the info, I figured it's going to need to be replaced and yes, I've heard it's a real pain in the butt in all aspects, oh well. Different to what others have said but thanks for that insight. 2 5357 Not recommended! The image presented is for a sublevel area. The footings are down deep with a load bearing wall supporting the upper floor level. If you did that drain… 8 10981 Always get multiple quotes, no matter how reasonable/cheap you think it is. I remember getting a few quotes for a pool fence, roughly around the same price, thinking the… 5 9984 |
