So, I am intrigued with your battle getting the certificates. How was this resolved?
Stewie
Browse Forums Owner Builder Forum Re: Macleay Island 7 Star 22Jul 15, 2022 3:12 pm The roofing screws are half done, wall sheeting screws are half done, time to move on to something else. I bought these wood look tiles from CheapTilesOnline for around $30/m2, I have now got similar wood look tiles for all the upstairs rooms, including bathroom. Overall I am pleased with the build of this house that costs less than $80,000 in materials. I do watch Grand Designs, and the Aussie version is the best by far, and still do not envy any of the designs, nor their budgets. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Macleay Island 7 Star 23Oct 19, 2022 10:33 am I am posting some photos of my off grid battery setup. I do not know why the BMS failed. I have simply decided to run without a Battery Management System from now on. In fact I have been running the 24V system on the left (with the "legit" sticker) for some time with no BMS and with no problems. Lithium Iron Phosphate Batteries have become progressively cheaper and are now below $1000 for 10kwh. The 48v 5kw Inverter Charger is around $700 and at the moment I have only two solar panels in series going to each inverter. I also have another two 24v 5kwh systems for downstairs. The whole system should be legit as per AS 4509 but I have yet to read the standards. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ 10 years ago was a different software than we use now. it has had a lot of changes over the past years. Improvments to the software and changes to how Nathers models need… 8 2425 DIY, Home Maintenance & Repair Are you going to have the frame exposed or are you cladding it with something. Usually if you are making an exposed frame you would use solid legs around 100x100 or… 3 7233 Well, it was the default we got with our deign, walking through the build last week felt ok, based on drawings on the floor, it is basically a metre, which is quite a big… 3 831 |
