Browse Forums Building A New House Re: Issues with newly laid bricks 2Feb 04, 2022 3:10 pm I think they are BS ing you. Height of standard bricks is 76mm with tolerance of +/- 50mm as measured on a stack of 20 bricks. This gives an average of 5mm per brick nominal variation. Mortar bed standard is 10mm with tolerance of +/- 3mm so there is 6mm available to adjust this to blend in. Also if the bricks are defective why did they accept and lay them? Check your states fair trading guide to standards and tolerances and brick manufacturers specs. Re: Issues with newly laid bricks 3Feb 04, 2022 4:19 pm Kippers01 I think they are BS ing you. Height of standard bricks is 76mm with tolerance of +/- 50mm as measured on a stack of 20 bricks. This gives an average of 5mm per brick nominal variation. Mortar bed standard is 10mm with tolerance of +/- 3mm so there is 6mm available to adjust this to blend in. Also if the bricks are defective why did they accept and lay them? Check your states fair trading guide to standards and tolerances and brick manufacturers specs. +/-50mm over 20 bricks is an average of 2.5mm not 5, but it's irrelevant as brick work should be layed using a gauging stick so it's to coursing. The bricks are 76mm and the gauge is 28 bricks to 2400mm height. If the used a gauging stick the bricks shouldn't have krept as they have done in the picture. It's poor workmanship pure and simple. The part about the bricks sinking under their weight is crazy talk. You should ask the builder if they are expected to continue sinking and why haven't the others brick sunk as well. Sometimes I just shake my head at the rubbish builders will say just to avoid doing the job right. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 The unit normally clips into a metal plate screwed to the wall, either plate is not flush, or unit not hooked in and could be hanging from the pipes partly, either might… 2 16269 I had new concrete laid, extended the alfresco and had the sidewalks concreted too. I noticed the concreter didn't put the expansion foam anywhere, there are expansion… 0 8349 I am looking at building a house. Has anyone used Construkt Homes (based in Adelaide)? Does anyone have experience with this builder? 0 6629 |
