Browse Forums Lighting + Lighting Design Re: Home Automation 29Jul 28, 2020 10:22 am hythakkar IamSAM I have installed Samsung SmartThings Wifi and setup is as below: 1) SmartThings (ST) Wifi Hub is setup as router 2) ST ios app installed. Plume app also installed 3) Z-wave Aeotec Garage Door opener with Tilt sensor 4) Z-wave Aeotec Water Sensor 5) Zigbee Samsung Motion Sensor Happy to answer your questions ! Hello IamSAM, I’m having little to no luck having the Aeotec GDC work reliably with ST. Are you please able to share which Device Handler you are using for the controller? Thanks Hitesh robertvandervoort : Aeon Garage Door - RV v0.1 Re: Home Automation 30Nov 01, 2020 7:26 pm MrChelseaFC IamSAM I have installed Samsung SmartThings Wifi and setup is as below: 1) SmartThings (ST) Wifi Hub is setup as router 2) ST ios app installed. Plume app also installed 3) Z-wave Aeotec Garage Door opener with Tilt sensor 4) Z-wave Aeotec Water Sensor 5) Zigbee Samsung Motion Sensor Happy to answer your questions ! Nice Any ideas how to automate window opening / closing ? We have two highset windows that are operated this way Building Standards; Getting It Right! 1. optional, you can but normally just use the earth from the main switch board 2. should be enough but the distance determines voltage drop - sparky should work it… 1 29430 We already paid for somfy motors for the blinds. The quote above was purely for “pre-wiring” so the blinds company can install the motors and blinds. That’s why we… 5 18363 Hi, you've probably already resolved this, however, Commbank will probably pay the funds to you after you send evidence the work is done regardless the change in the quotes. 1 36596 |
