Browse Forums Kitchen Corner Re: Kitchen and appliances damaged by kitchen company 4Aug 06, 2019 11:59 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Kitchen and appliances damaged by kitchen company 8Aug 06, 2019 3:02 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Kitchen and appliances damaged by kitchen company 13Aug 06, 2019 6:49 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Kitchen and appliances damaged by kitchen company 14Aug 06, 2019 10:13 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Kitchen and appliances damaged by kitchen company 15Aug 06, 2019 11:08 pm SaveH2O If you are worried about that first photo it's carcass board which is usually HMR PB. The end panel needs to be installed which is why you can see the nail and screws. That's not an issue as it gets covered. The rest of it is not great. It looks like 2 pac and occasionally there will be little blemishes in it but if this was a kitchen I was installing I would take those panels back to my painter and have them redone. If I wouldn't be happy with it in my own house I won't put it in a customers house. The dented DW is just poor. If the kitchen installer is also supplying/installing the DW then its on them to rectify the damage. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Kitchen and appliances damaged by kitchen company 16Aug 06, 2019 11:51 pm chippy If you are worried about that first photo it's carcass board which is usually HMR PB. The end panel needs to be installed which is why you can see the nail and screws. That's not an issue as it gets covered. Thanks. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Kitchen and appliances damaged by kitchen company 17Aug 07, 2019 11:25 am SaveH2O Raejo Partner is pressuring me to concede just so we can move home. This is what some tradies and builders anticipate. Have you paid them in full? About time that some of the forum's kitchen pros gave some inside advice. Not paid in full but not much left either unfortunately Re: Kitchen and appliances damaged by kitchen company 18Aug 07, 2019 11:34 am chippy @SaveH2O If you are worried about that first photo it's carcass board which is usually HMR PB. The end panel needs to be installed which is why you can see the nail and screws. That's not an issue as it gets covered. The rest of it is not great. It looks like 2 pac and occasionally there will be little blemishes in it but if this was a kitchen I was installing I would take those panels back to my painter and have them redone. If I wouldn't be happy with it in my own house I won't put it in a customers house. The dented DW is just poor. If the kitchen installer is also supplying/installing the DW then its on them to rectify the damage. I got my own dishwasher it was new in packaging and they installed it and then removed it for the flooring. The kitchen project manager is denying liability. Re: Kitchen and appliances damaged by kitchen company 19Aug 07, 2019 11:37 am SaveH2O Just having a closer look at your first photo...do you have a contract that states the type of material used? No unfortunately not I just trusted it was the material he showed me. I feel silly now though should have that included in the contract Re: Kitchen and appliances damaged by kitchen company 20Aug 10, 2019 10:42 pm Raejo chippy @SaveH2O If you are worried about that first photo it's carcass board which is usually HMR PB. The end panel needs to be installed which is why you can see the nail and screws. That's not an issue as it gets covered. The rest of it is not great. It looks like 2 pac and occasionally there will be little blemishes in it but if this was a kitchen I was installing I would take those panels back to my painter and have them redone. If I wouldn't be happy with it in my own house I won't put it in a customers house. The dented DW is just poor. If the kitchen installer is also supplying/installing the DW then its on them to rectify the damage. I got my own dishwasher it was new in packaging and they installed it and then removed it for the flooring. The kitchen project manager is denying liability. I have more photos it’s also scraped on the sides It's hard to comment as the photos area bit dark ( you might need a new 15 - just got one and wow ) Jokes aside, I can see one member that is cracked. I would find a… 2 2439 The coupling, which is made from flexible PVC, needs to comply with AS/NZS 4327 which specifies the requirements for metal banded flexible couplings used in low-pressure… 1 2223 Thanks, we are headed in the direction of grinding, but unsure of what to do on top of that? 2 1739 |
