Browse Forums Building A New House Re: Project builder for steep blocks 5Dec 07, 2017 9:12 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Project builder for steep blocks 13Feb 12, 2018 6:35 am schmalex There are a lot of great architects in Sydney. I recently came across an interesting house in Lane Cove that was on a site with a 12 meter fall in a significant bush fire danger zone as well. Built from Integrated Concrete Form blocks as well. I had a good chat with the builder of this project as well. Re: Project builder for steep blocks 14Aug 17, 2018 12:13 am MisterSlope @schmalex There are a lot of great architects in Sydney. I recently came across an interesting house in Lane Cove that was on a site with a 12 meter fall in a significant bush fire danger zone as well. Built from Integrated Concrete Form blocks as well. I had a good chat with the builder of this project as well. What do you think of the builder? Did you get to talk to the owner? Are they happy with the result? We are building in upper north shore and the land has a slight slope. Very interested in talking to more builders. It will be greatly appreciated if you could share your insight. Re: Project builder for steep blocks 15Aug 17, 2018 12:13 pm If possible, consider 3 level split. Should be suiting your 5 m quite well. I have a split design on 3 m fall, cut and fill sorts most of the issues: I have around 1 m cut from the back + 1.7 m split with some fill at the front. Yes, I would still have to pay extra for the retaining walls and high quality rafted slab with piered footings, but those costs are quite reasonable. My neighbour certainly had paid more for his excavation and almost 50 tipper trucks. If you are thinking about ICF (which you probably should on a very sloping block), check out Durisol/Nexcem ICF which far better/more ecological/fire safe alternative to standard polystyrene ICFs (durisol.com.au). When comparing to brick, it won't be settling at all. Building from ICF can take a bit longer, but with current Sydney pricing, you can build your walls cheaper than brick veneer and they will be rendered throughout, so no gyprock. Also, they are breathable, have good thermal mass and offer good insulation. They can also recommend you a builder. WBR, Alex Re: Project builder for steep blocks 16Aug 17, 2018 10:25 pm Huggies What do you think of the builder? Did you get to talk to the owner? Are they happy with the result? We are building in upper north shore and the land has a slight slope. Very interested in talking to more builders. It will be greatly appreciated if you could share your insight. It was the builder's first time with the product and it was recommended to him by the client. Both the architect and the builder were pretty keen once they had a chat with Zego. Zego was the ICF supplier in this project. I have heard good things about the builder and he is essentially carrying on his father's business. We spoke on multiple occasions and he made the time to chat with me as well. Architect is currently looking into other projects near the Blue Mountains to use ICF. Happy to pass on the architect and builder's details if you want. I'm pretty sure if you google you can figure it out. Re: Project builder for steep blocks 17Aug 17, 2018 10:28 pm alexp79 If you are thinking about ICF (which you probably should on a very sloping block), check out Durisol/Nexcem ICF which far I never heard of Nexcem before.. I am surprised the about the claim for zero blow outs. It doesn't make sense how that would be possible. Re: Project builder for steep blocks 18Aug 17, 2018 10:42 pm MisterSlope alexp79 If you are thinking about ICF (which you probably should on a very sloping block), check out Durisol/Nexcem ICF which far I never heard of Nexcem before.. I am surprised the about the claim for zero blow outs. It doesn't make sense how that would be possible. Not sure where exactly this specific claim is coming for, but Durisol material itself is MUCH stronger than polystyrene, it is often referenced as "woodchip"-based light concrete. In Europe, people are actually building 3 storey houses out of woodchip concrete solid blocks as their compression strength can easily go up to 3 mPA, it also can bend quite well and it is really hard to break the block even with a sledgehammer. Re: Project builder for steep blocks 19Aug 18, 2018 9:31 am alexp79 MisterSlope alexp79 If you are thinking about ICF (which you probably should on a very sloping block), check out Durisol/Nexcem ICF which far I never heard of Nexcem before.. I am surprised the about the claim for zero blow outs. It doesn't make sense how that would be possible. Not sure where exactly this specific claim is coming for, but Durisol material itself is MUCH stronger than polystyrene, it is often referenced as "woodchip"-based light concrete. In Europe, people are actually building 3 storey houses out of woodchip concrete solid blocks as their compression strength can easily go up to 3 mPA, it also can bend quite well and it is really hard to break the block even with a sledgehammer. the only issue i see is accessibility to materials like this and experienced trades people who have used it. The only downside I see with ICF is the issue of blow outs. Re: Project builder for steep blocks 20Aug 18, 2018 11:56 am Montgomery homes claim to be the sloping specialists Hi Everyone, One of my favourite parts of a build is when the temporary fence comes down and the home begins to reveal itself. It also means we are on the home straight… 103 372779 Those span tables can be pushed a little for a low deck if you dont mind a little flex. Last deck I did, I pushed it a little and it was still rock solid - no noticeable… 6 14543 As a tradesmen get a private inspector although I don't think there worth it in their profession themselves the reminder they serve to the tradesmen doing the work is… 3 28039 |
