Browse Forums Building A New House 1 Sep 04, 2017 8:09 am M Y C U S T O M C O R A L B R O N T E 43 ...............Kitchen! 16 Nov 2016 https://forum.homeone.com.au/viewtopic.php?f=31&t=79581 Re: Squeaking floor 3Sep 04, 2017 8:49 am M Y C U S T O M C O R A L B R O N T E 43 ...............Kitchen! 16 Nov 2016 https://forum.homeone.com.au/viewtopic.php?f=31&t=79581 Re: Squeaking floor 4Sep 04, 2017 10:36 pm That's concerning, sometimes squeaks etc can be from a lack of adhesive (liquid nails) underneath the yellow tongue this seems much more significant than lack of glue/nails Could be steel rubbing, lack of fixings/joist hanger hardware etc into posi struts/floor joists or a combo of everything Re: Squeaking floor 5Sep 05, 2017 4:20 am x M Y C U S T O M C O R A L B R O N T E 43 ...............Kitchen! 16 Nov 2016 https://forum.homeone.com.au/viewtopic.php?f=31&t=79581 Re: Squeaking floor 6Sep 05, 2017 7:00 am Could be multiple things, if there is any access in the subfloor would be good to check in there, otherwise pop some down lights or anything like that out grab a torch and get your partner to walk around again and have a look, see if you can narrow some things down Re: Squeaking floor 7Aug 05, 2018 12:21 pm MrsJM Coral have told me once that steel making noise is normal... but really??? This is normal after 9 months?? This is what it sounds like when my hubby is just walking around normally upstairs and I am downstairs. Edit: video link kindly posted below thank you Has the squeaky been fixed? Stopped 100%? I probably have the same issue, different builder isn't a garage level with the rest of the house a given? pretty sure they 'came around' long time ago. if you have a flat block, the garage is usually level with the rest… 1 18530 bec of more thickness and underlay i prefer laminate. also my builder covers laminate only. 2 2402 Assuming you've modelled the TB8, TB10, TB12, TB2 & J1 joists/LVLs there, it appears as per drawing to me. There maybe should be an additional J1 between TB10 and T12 if… 3 32843 |
