Browse Forums Landscape & Garden Design Re: Newcastle landscape journey 69Mar 30, 2017 10:14 pm Customised Burbank Indigo/Hawthorn in Officer VIC https://forum.homeone.com.au/viewtopic.p ... 2#p1680752 Re: Newcastle landscape journey 74Apr 04, 2017 4:07 pm So much mud We'll need to work out how to stop water pooling here. We were thinking of some little retaining wall needed and a low tropical garden as it won't get any sun. I thought a strip drain at the base of the wall outside the column line but now there's concrete right where the drain would go through. Argh I don't know. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ A heap of water come from next door and drains across our yard. A lot gathers in front of and under these stairs. I hope mosquitos aren't breeding under there Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The water then finally pools under/at the base of this garden where I've spread out some gravel to try lessen the mud. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Soooo lots of drainage to work out. Any suggestions let me know! Re: Newcastle landscape journey 75Apr 04, 2017 4:43 pm I'm sorry I can't help with drainage but your patio is looking fantastic! Re: Newcastle landscape journey 76Apr 05, 2017 9:56 am If you wants to stop future water pooling along the side of patio 1.Once you have finish building these plants will be under shade, move plants between the fence and patio.... replant those some where, plants you have now will not look good in 3 to 4 year as they needs full sun. 2. dig trench and install drainage system as below just like how you have done at the front ...I know it will be too much work. I will be doing this along the side of the house next to guest room/study as rain water rush out to our land as we are on lower side. So this drainage will be carry out into a large rocks and gravel pit trench under open garden space. I'm not looking forward to do this ....but its on must do list! Please post if you comes up with other solutions. Build Thread : viewtopic.php?f=31&t=81624 Re: Newcastle landscape journey 77Apr 05, 2017 3:59 pm Oh man i never thought that those photinia along the fence would die ... They get full sun on the top, but that's probably not enough is it. They look so good now too! What a real shame. How disappointing. lol Re: Newcastle landscape journey 79Apr 10, 2017 4:16 pm Today we went to the pool and furniture shop. Decided on a slightly larger pool and will heat it. We sprayed it out in pink when we got home today. If we put the pool in then the timber steps would go (need to come out to get the machine up to dig the hole anyway), and replace with a garden bed. Then would take the other end out that has the angled edge and covers part of the end of the patio. Now to find a mortgage broker that actually shows up! We also bought this dining set for outside. The table, 10 chairs and the blue mat . It's from Outdoor Elegance. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Newcastle landscape journey 80Apr 10, 2017 9:56 pm Wow. Looks fabulous. You must be so pleased! And I see you have decided on the pool! Yay. Renders? 😎 You should check your detail drawings, it may show downpipe within brick pier. 14 14676 Hi, you've probably already resolved this, however, Commbank will probably pay the funds to you after you send evidence the work is done regardless the change in the quotes. 1 36602 Ideally you would engage a landscaper to give you some insight what they may need in the space to make your vision come to life… 1 14393 |
