Hi all,
I know this has been discussed in the forum a few times but I am hoping for someone to post a picture of their hideaway bin that is attached to the cupboard door under the sink so that you only have to open the door and the bins will slide out with it.
Our kitchen mob is to use KK4F hideaway bin (see pic below) which means that you have to open the cupboard door and then access the bins via a handle pull which I am not liking.
Is KK6F (pictured below) can be used to be attached to the cupboard door?
Below is another model but I am thinking that the above can be installed the same way. (ie just have to be side mounted and use door brackets)
Much appreciated if you can post photos please..
Cheers!
