Browse Forums Building Standards; Getting It Right! Re: [Urgent] Advise please - Weep hole 2Jul 20, 2016 6:28 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: [Urgent] Advise please - Weep hole 3Jul 20, 2016 6:44 pm Our Custom Dale Alcock build in the Village at Wellard https://forum.homeone.com.au/viewtopic.php?f=31&t=78620 Re: [Urgent] Advise please - Weep hole 8Jul 20, 2016 7:22 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: [Urgent] Advise please - Weep hole 16Jul 22, 2016 9:33 am Not just for drainage but also for ventilation. If it's still revealed halfway after landscape I'm still not bothered. But to be fully covered (especially with paving we're talking compacted groundwork) then I'm not so sure... again if the weep holes are positioned properly perhaps the paver inge were set too high? On the way to inspection now so will see what their response is.... Re: [Urgent] Advise please - Weep hole 18Jul 23, 2016 4:24 pm ZoePerth Right but is it an issue to occasionally have a half inch of water sat in the cavity? I'm not being awkward I'm genuinely asking. It's how I've seen lots of builds in WA. It's a house, not a bath. covered weep hole are not compliant. Landscaping half way up weep holes or not far enough below is non compliant. Re: [Urgent] Advise please - Weep hole 19Jul 24, 2016 2:53 pm ZoePerth Surely if water is to drain out of the weep holes that can still happen when covered with grass or soil or pavers since they're all permeable? Seriously? Regulations (compliance) are formulated for different reasons and purposes. The matter of non compliance breaching the termite barrier is just one other reason for the weep hole mandated height compliance. ZoePerth Right but is it an issue to occasionally have a half inch of water sat in the cavity? I'm not being awkward I'm genuinely asking. It's how I've seen lots of builds in WA. Too many cowboys. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. it depends on the natural ground level, if they excavated their boundary wall needed to be built as a retaining wall. If you filled, which sounds like the case then you… 1 7583 I know foam has been around since the 90's and CSR started manufacturing Hebel in 1989, so it's definitely possible 5 6165 You are correct. Just read through all the ncc rules and 75mm is the minimum requirement for me. 4 11956 |
