Browse Forums Building A New House Re: Frame standards? 7Nov 02, 2008 2:40 pm “It's just as unpleasant to get more than you bargain for as to get less” George Bernard Shaw. Re: Frame standards? 10Nov 04, 2008 1:10 am “It's just as unpleasant to get more than you bargain for as to get less” George Bernard Shaw. Re: Frame standards? 12Nov 04, 2008 10:01 pm Thanks kindly for the info.
Regards KW........ “It's just as unpleasant to get more than you bargain for as to get less” George Bernard Shaw. Re: Frame standards? 13Apr 18, 2010 9:09 am I needed a copy of the structural engineering for the frame and bracing so Alex the building surveyor can do his inspection. I was told by Carlisle unless its a double storey engineers no longer do a structural report or plan for frames. Instead all frames for single storey are built according to section 16 84 of the building code Does anyone know anything about this ? or have a copy of the section 1684 re frame & standards. Subsequently I found out the Truss and frame manufacturer is the source that can provide me with this info. If I dont get this info prior to the inspection ,Iam wondering if its a worthwhile getting one because how will he know where the bracing is supposed to go etc? each house is different. Re: Frame standards? 14Apr 18, 2010 9:33 am Hi andy, if your in SA I can help you out. If not you can buy a copy through "SAI GLOBAL" http://infostore.saiglobal.com/store This is 100% true. You can not hang anything on steel frames. very frustrating 8 10606 2 9680 We are having a bathroom reddone. The builders are putting down two coats of waterproofing and then screed and then another coat of waterproofing. This is what I have been… 0 3431 |
