Browse Forums General Discussion 1 Aug 18, 2013 1:44 am I jut moved in a single storey home that equipped a fully electric gravity fed rooftop hot water system from the early 1970s. It still works well, but provides extremely low hot water pressure and is basically unusable for doing the dishes or having a shower. What is the easiest way to increase the water pressure from the tanks on the roofs to all the taps/hotwater tanks in the house? I know a new HWS would do, but i'm tight on budget. Any help greatly apreciated....cheers Re: Low Pressure gravity rooftop fed HWS, best solution? 2Aug 18, 2013 2:39 am There are several small pumps sold for exactly that purpose. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Low Pressure gravity rooftop fed HWS, best solution? 3Aug 28, 2013 11:48 am Hi Arthurx, Yes, we've worked similar systems before. Basically you are using the weight of the water in the tank to push the hot water out of the tap. If you want any real pressure you do need to replace the entire system, but yes SaveH2O is correct there are options to increase the water pressure. The hot water booster pumps usually only increase pressure by 100 kpa which is minimal. Most options on the market don't have a pressure switch to turn the pump on when you open a tap or can't handle the heat. I hope that helps. Also at the bottom of page 4... ...and from 28 November 2023 a heat pump water heater, gas boosted solar water heater or electric boosted solar water heater can be… 9 1316 First time building 2 storey home, is under construction (in Framing stage) in NSW. I have 3 toilets and need bidet spray in… 0 17437 |
