Browse Forums Building A New House Re: Our second home- JG King Memphis- Eaves question 21Jul 19, 2015 6:41 pm Sorry for the confusing post. But of the house stays where it is we cant have eaves, if we move it over 200mm we can have 200mm eaves. As you said long term we plan on having entertainment area on the west side of the house i know it only 200mm but it all counts. There will be a drive through on our garage so that will be our rear access. Our choice of eaves to begin with was 450 or 600mm. Our Build Thread - JG king Memphis Re: Our second home- JG King Memphis- Eaves question 22Jul 19, 2015 6:47 pm Yeah I probably would go without them, rather then downgrade the outdoor area. And considering it's not going to be noticeable from the front because the garage won't, it won't be out of balance. Most houses these days are built without them. Re: Our second home- JG King Memphis- Eaves question 23Jul 19, 2015 7:24 pm Yes i am leaning that way but i do think they help complete a house i think they look a bit nude without them. But i think the outdoor area is more important. Our Build Thread - JG king Memphis Re: Our second home- JG King Memphis- Eaves question 24Jul 21, 2015 10:24 pm GGGrrr just seen on our developers website our land has been pushed back from October to December... Nice of them to tell us. Not the worst thing but communication would be nice. So we have decided to delete the eaves and leave the house where it is. We'll see what the drawings come back like Our Build Thread - JG king Memphis Re: Our second home- JG King Memphis- Eaves question 25Jul 21, 2015 11:39 pm That's frustrating! I hear your pain. We don't get anything from them developers or real estate agents, your lucky to have a website that gives any information. We have to make the call up ourselves. Ours was due to settle in September last year! We have been past the date if we want to pull out we can, but there is nothing as good in size at this price. Land in a decent size is around the 200k mark! Such a rip off. Anyway. I was thinking its a pity you can't flip the front part of the house around and then have the garage right along the fence line like we are doing, but then that wouldn't work out it would push your house over still. Re: Our second home- JG King Memphis- Eaves question 26Jul 22, 2015 8:56 am Yes it's frustrating, not as bad as your situation though. And agreed with the land prices we are a bit above the amount you quoted.... Have you sold your house yet or are you waiting for the land to title? We've got ours on the market so it looks like we'll be homeless a bit longer, but it look like we should be able to move in with the father in-law after all. Which will be good money wise. With the house placement we are set which side our cross over has to be as at the other side of our front, there is a easement across the nature strip. The way we decided to position the house on the block was as far forward and as close to the fence on the east side to maximise the side entertaining and backyard. We could of put the garage on the fence line and it wont cost a lot of space but we have chosen not to at the moment. If the drawings come back and we aren't happy with the look without the eaves we still might move it. Our Build Thread - JG king Memphis Re: Our second home- JG King Memphis- Eaves question 27Jul 28, 2015 11:22 am Ok we had a trip to Delta carpets in Ballarat (they supply JG's carpets and floorboards) to see what we had to choose from and the answer was too much! We are fairly set on the timber laminate but are still deciding on the carpet. We are looking between Cat 2 and Cat 3 carpet. We haven't officially started colours yet as we are waiting for drawings to come back, so cost could play a part in the selection too. Below are the carpets we liked. Cat 2- With the pattern and twist ply makes it harder wearing but not as plush, but we would upgrade the underlay too if we went this way Cat 2 pattern and cat 3 this is more plush/softer just not sure how it will hold up against the kids We also like the dark little square as something totally different this is also CAT 3 The browns tend to flow on from the floor board where as the dark creates a good contrast. What are peoples thought? Plush v hard wearing, colours? And yes this could change a bit once we go through the other selections to make sure it all works together Our Build Thread - JG king Memphis Re: Our second home- JG King Memphis- Flooring Choices 28Jul 30, 2015 9:23 pm YAY got our preliminary drawings today, not a huge amount of change from base but its great to see our touch on it. We have noticed a few errors but nothing major. Here is the floor plan Note: where tiles are picture will most likley now be the timber laminate above. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Elevations Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ On the front we will be changing the window next to the garage door, it doesn't suit, also we will be changing how much and where will be render but haven't quite decided that yet, any ideas? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ On the left elevation the middle sliding door is meant to be a double opening One problem we have noticed ia that in the en-suite we extended the vanity but now we don't know where the towel rail should go.... under the window is 800mm high which I think is to low. Any ideas different type of towel racks? En-suite Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Overall pretty happy few things we need to address but nothing major, I'm sure as we continoue with colour etc. we will make more changes too. Our Build Thread - JG king Memphis Re: Our second home- JG King Memphis- prelim drawings 29Jul 30, 2015 9:46 pm From the elevations, looks like you're having FC infills above the side and rear windows. If your budget allows, I'd go with brick infills. Think it always looks much more 'finished'. Good luck with the build. Re: Our second home- JG King Memphis- prelim drawings 30Jul 30, 2015 9:50 pm Thanks for the comment yes I agree and it's something I want to price up. I agree it does look better, just need to see if the budget allows it. Our Build Thread - JG king Memphis Re: Our second home- JG King Memphis- prelim drawings 31Jul 30, 2015 9:58 pm We're building quite a large house with JGK, and brick infills cost about $1100. Re: Our second home- JG King Memphis- prelim drawings 32Jul 30, 2015 10:01 pm Thanks is that for all windows or per window? do you have a build thread? Which floor plan are you building? Our Build Thread - JG king Memphis Re: Our second home- JG King Memphis- prelim drawings 33Jul 30, 2015 10:14 pm surtees Thanks is that for all windows or per window? That's for all windows. About 15 from memory. Ours is a custom plan, and no thread. Intended to, but not organised enough Re: Our second home- JG King Memphis- prelim drawings 34Jul 30, 2015 10:25 pm Ah that's not to bad, I'll have to get it priced and then get through colours and electrical to see how far the money goes, but yes I do like the idea of doing it. If you get inspired to do a thread I'll read it! Our Build Thread - JG king Memphis Re: Our second home- JG King Memphis- prelim drawings 35Aug 03, 2015 3:15 pm Hi Surtees! I'm new to the forum and haven't started a thread yet, although I should probably do that soon. Following your thread. We are building with JG Geelong too (building in Colac)! and we are MIGHTY unimpressed so far. It has been 4 months since deposit and our contract has all kinds of things wrong and left out. We don't even have our prelims back!. Anyway we're building the Reve 1B with a few alterations. Can't wait to start building, it's going to look amazing This is our altered plan Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Our second home- JG King Memphis- prelim drawings 36Aug 03, 2015 3:40 pm Hi Wincey, Sorry to hear, so far we have found dealing with them great. The main reason or prelim drawings took a month was we had made a few mods that they question or we had to modify again to fit in building envelope etc. Do you have full contract with prelim drawings? We have paid deposit and signed initial documents, but are a way off having full contract. We don't know our site cost yet so I wont sign before then. Hopefully things improve for you soon! Our prelim drawings had a couple of things wrong but nothing major, but I guess that's why they are prelim. We have told them about that a couple of other things we wish to change so they should hopefully have that ready by the time we head to colours. Love you mods putting the WIP to the study nook opens up that kitchen area so much. that's a huge laundry! Let me know when you start a thread and I will follow your build, There are a few other JG builds on here too. Our Build Thread - JG king Memphis Re: Our second home- JG King Memphis- prelim drawings 37Aug 03, 2015 3:44 pm In regards to the ducted heating, we are definitely upgrading ours to high efficiency. It's worth it if you're going to live in the house, as bills can get high if you run it a lot. Brick infills look nicer, FC sheet looks a bit tacky but it's not really a necessity. With your ensuite towel rail dilemma, you could put it under the window. You could make the window higher and shorter if you wanted, but not sure if the towel rail there would clash with the opening of your shower door?? Have you considered using towel hooks instead?? They look nice and don't take up much space. You could put them up on the walls next to the sides of your vanity or outside the ensuite on the back of the shower wall as you walk in the door or on the other side on the back of WC wall towards your WIR. We went to floorworld in geelong, same company. We are having carpet like your Cat 2 one. We are having Stainmaster Eversoft. I would definitely go with the one with the squares in it, if you feel them with your fingers and also walk on them, you will see that the debris is less likely to sink down into the fibres quickly, better for children, whereas the Cat 3 one (we have this in our current house, atrocious) spreads more when walked on and allows things to sink easier. I would choose the darker charcoal colour as I think the taupe one will look a little dull and boring, it doesn't stand out against your floorboard. But in saying that, it's simply my own opinion and nobody's tastes are the same Re: Our second home- JG King Memphis- prelim drawings 38Aug 03, 2015 4:03 pm We have moved on from New Home Estimate and RAI's, we have a Formal Building Quotation now (which is being amended as some things were still wrong). Still lots of Provisional Costs, until our Preliminary plans come back, which should hopefully be this week. All pricing will be firm after they come back, except for colour appointment choices of course. Haven't done our colour appointment yet. Been researching colours, paints, benchtops, cupboards etc for ages now and essentially know what we want, but it is really hard trying to tie all colours in together to make sure it turns out nicely. We're having Vinyl Plank flooring, seems to be the best option. Do you have a colour scheme? Have you decided on things like paints and bricks etc yet? Bricks are so hard, they look nothing like the samples when they are built on a house! Re: Our second home- JG King Memphis- prelim drawings 39Aug 03, 2015 4:57 pm Yes we have gone with the upgraded ducted this also allows zones we have zoned of the living and bedrooms. We are looking at a couple of different towel rack options and will add your ideas to the list. I agree with the carpet selection type but need to convince the wife... We have been discussing about whether we flow through from floor board to carpet or have totally different tones, I think I've got a foot in each camp on this one. Yes we are at FBQ stage as well but this is still full contract stage so it's time to get it all right now otherwise the cost can hurt on the other side. We have a partical idea on some of the things we like colour wise and no idea on other things, we have been drivning around new estates looking at facades and colours and going through more display homes for interior.... I think the house will just be one colour inside to start with as the feature walls/rooms were over priced IMO. The Vinyl planking is a good idea just not sure on it. we are leaning to a tan/brown brick but yes samples are not the same as the finished product. Our Build Thread - JG king Memphis Re: Our second home- JG King Memphis- prelim drawings 40Aug 03, 2015 6:07 pm I can understand your reasoning for carpet. I have this odd view where things have to be either almost exactly the same or entirely different. We aren't signing until we get prelims back and all the costing is updated and the little errors fixed. I was hoping to get feature walls, but have no idea how much it will cost yet We're looking at doing a light-med grey for all internal walls. I want to just stick with the Neo façade as I think the extra cost is unnecessary for something we're not going to look at 24/7, but the hubby is set on going with the Trent, so we are divided. We have called the brick companies and obtained some addresses so we can go see the bricks we like (unfortunately all in geelong ). Leaning towards Selkirk Indigo or Boral Heathwood at the moment. Yes, flooring is difficult but we borrowed some samples of vinyl planks from our local flooring place and were surprised by how nice they were, we fell in love. Plus at least we don't have to worry about spills wrecking the floor from the kids/pets Oh I forgot to respond about my laundry, it's to allow room to put clothes drying racks in! Having laundry space is so practical! Sorry, I feel like I'm hijacking your thread We are building a second dwelling and are currently selecting window and door frames. We want to blend into the forest and also bring out the stone work and the fake wood… 0 20045 1 10169 I would never build with Fowler homes. I built with them in 2021 and till date maintenance issues are pending. All their existing trades and businesses don't work with… 14 109679 |
