Browse Forums Building Standards; Getting It Right! Re: Rising Storm Water Pit 8Mar 01, 2023 1:22 pm ponzutwo 4re5 Hi, sorry to resurrect this old pots, but how you solved this issue. I have the same situation with the exception that my pit doesn't have a grate but concrete lid cover. Regards, doesn't sound like its the same type of drain, so its not entirely the same issue. Given it has a concrete cover on it, Its unlikely to be for overflow. should be ok to put a riser on it. Check with council. Or if this is access to your sewer inspection, you can just extend it without contacting council. In my old place I put a marker next to it and cover d it in mulch lol. Hi, yes you are right. I checked and is not a overflow is just a inspection pit to where my neighbour has his LPD for the stormwater. Regards, Thanks for that, the PVC pipe is still about 40cm below ground level and it sticks out of the sand with no end cap or anything on it just open pipe, is this the finished… 2 10839 Hello I am developing 2 side by side units. Wish someone can help me on the following questions 1) Which stage should be the storm water pipe installed during the new… 0 8191 If you need to be able to access these then you may need to dig them out and cut them so you can add a socket and a riser to the required height. We normally add a… 1 7078 |
