Browse Forums Building Standards; Getting It Right! Re: Rising Storm Water Pit 3May 09, 2021 8:36 am "Your neighbor is responsible for their own drainage." that is not correct, neighbour is responsible for run off, not drains drain is part of easement and op's garden may not be the lowest on that section of pipe sounds like op's garden may have been raised, before or after construction Re: Rising Storm Water Pit 4May 11, 2021 11:36 pm Is the pit a surcharge pit? If there is a shared stormwater easement you need a surcharge pit to allow overflow overland in extreme rain events. These pits are normally above the surrounding ground level at the last point before leaving your site. You might be able to raise the pit if you install a new pit connected to it at a lower level to allow surcharge. If you raise it without a surcharge point your stormwater will flow upstream out of their surcharge pit flooding their property. best to listen to the council, or get a hydraulic engineer to help you or download AS3500 and read the section on stormwater drainage. Re: Rising Storm Water Pit 5May 13, 2021 1:10 pm "But maybe you could just add a second lid up higher that allows water entry" Yes I'm going to have a lid on top of the riser but I don't see it's possible for the flood water to rise that high "sounds like op's garden may have been raised, before or after construction" Yes. the garden has been raised so that it's level. Originally, it slopes from the slab to the pit (600mm for 4.5m) "Is the pit a surcharge pit?" It looks like a surcharge pit with a grate on top. "If you raise it without a surcharge point your stormwater will flow upstream out of their surcharge pit flooding their property." I don't understand this part. Can you elaborate? The whole street is pretty much has the same issue. Most of my neighbours choose option 2. To help you easily imagine, the ground level (which is also the pit level) of all slots in the street is sloping. Let say my ground level (and pit level) is x, then the whole street looks like this: [x+50] [x+40] [x+30] [x+20] [x+10] [x (mine)] [x-10] [x-20] [x-30] [x-40] [x-50] Re: Rising Storm Water Pit 7Mar 01, 2023 1:09 pm 4re5 Hi, sorry to resurrect this old pots, but how you solved this issue. I have the same situation with the exception that my pit doesn't have a grate but concrete lid cover. Regards, doesn't sound like its the same type of drain, so its not entirely the same issue. Given it has a concrete cover on it, Its unlikely to be for overflow. should be ok to put a riser on it. Check with council. Or if this is access to your sewer inspection, you can just extend it without contacting council. In my old place I put a marker next to it and cover d it in mulch lol. Re: Rising Storm Water Pit 8Mar 01, 2023 1:22 pm ponzutwo 4re5 Hi, sorry to resurrect this old pots, but how you solved this issue. I have the same situation with the exception that my pit doesn't have a grate but concrete lid cover. Regards, doesn't sound like its the same type of drain, so its not entirely the same issue. Given it has a concrete cover on it, Its unlikely to be for overflow. should be ok to put a riser on it. Check with council. Or if this is access to your sewer inspection, you can just extend it without contacting council. In my old place I put a marker next to it and cover d it in mulch lol. Hi, yes you are right. I checked and is not a overflow is just a inspection pit to where my neighbour has his LPD for the stormwater. Regards, Thanks for that, the PVC pipe is still about 40cm below ground level and it sticks out of the sand with no end cap or anything on it just open pipe, is this the finished… 2 10735 Hello I am developing 2 side by side units. Wish someone can help me on the following questions 1) Which stage should be the storm water pipe installed during the new… 0 7997 If you need to be able to access these then you may need to dig them out and cut them so you can add a socket and a riser to the required height. We normally add a… 1 6976 |
