Browse Forums General Discussion Re: Question about regulations re window sizes 3Dec 24, 2018 8:36 pm Build insta: https://www.instagram.com/ourtreechangebuild/ Re: Question about regulations re window sizes 4Dec 25, 2018 9:48 am If you want the master and theatre room to be dark then I suggest you consider flipping the house (mirror image) so that these rooms face south and the living areas face north. At the moment you have your threatre and master on the North side so they will still get quite a bit of light even through the small windows. Re: Question about regulations re window sizes 5Dec 25, 2018 11:35 am Me? I'd just stick a telly in the living room. This home theatre room allocation is going to look so passe down the track. Is it good allocation of home space? PS And can you imagine the sound system booming away next to the master bedroom? Re: Question about regulations re window sizes 6Jan 03, 2019 9:56 pm kks Me? I'd just stick a telly in the living room. This home theatre room allocation is going to look so passe down the track. Is it good allocation of home space? PS And can you imagine the sound system booming away next to the master bedroom? It's a good allocation of home space for us, as is the positioning of it next to the master, but thanks for your off-topic input. Build insta: https://www.instagram.com/ourtreechangebuild/ If you don't want to annoy the neighbours then simply get yourself some good head phones. For me the sound is much better using headphones. The NCC (National Construction… 1 26164 You need to reference the manufactures installation guide, your supplier may have strengthened the base where it is not required to sit on a bed. 1 1805 OK it's been a little while! I've been busy getting time where I can to work on this. I started by grading a pad (borrowing a… 26 19968 |
