Browse Forums Building A New House Re: Building the Marriott 47 (Waldorf) by Porter Davis QLD 2Jan 13, 2018 4:01 pm Instagram blog: https://www.instagram.com/ourforevertonhome/ Re: Building the Marriott 47 (Waldorf) by Porter Davis QLD 3Jan 13, 2018 4:02 pm Instagram blog: https://www.instagram.com/ourforevertonhome/ Re: Building the Marriott 47 (Waldorf) by Porter Davis QLD 4Jan 13, 2018 4:08 pm Instagram blog: https://www.instagram.com/ourforevertonhome/ Re: Building the Marriott 47 (Waldorf) by Porter Davis QLD 7Jan 13, 2018 4:24 pm Instagram blog: https://www.instagram.com/ourforevertonhome/ Re: Building the Marriott 47 (Waldorf) by Porter Davis QLD 8Jan 13, 2018 4:26 pm Instagram blog: https://www.instagram.com/ourforevertonhome/ Re: Building the Marriott 47 (Waldorf) by Porter Davis QLD 10Jan 13, 2018 6:05 pm For external colour selections, we went pretty much the same as the QLD display home: Ground floor render - Ashlite half strength Weatherboard cladding - Wattyl grey pebble 3/4 strength Gutters - Basalt Fascia - Surfmist Downpipes - Shale grey Garage door - Surfmist Window mouldings/balustrade/posts - Wattyl white Pretty much the same as the photo below, however we went surfmist fascia instead of basalt. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ For internal colour selections we went pretty much the same as the display as well. Originally we had planned to go for a more classic hamptons look with dark timber floors, white walls, white architraves, white cabinetry, black doors etc. The reason we changed our mind was because of our inside dog. We had hardwood floors in our last house and they just got horribly scratched from him, and we plan to get another dog once we move in, so decided tiles would be more suited. Below are our internal colour selections: Wall colour - southwards Internal doors - Wattle white Skirting/architraves - Wattyl white Stair case risers, stringers, posts - Wattle white Stair case hardrails, treads - PD Black stain Below are most of our tile selections: Our main downstairs tile which we are doing after handover which we took into the display to see how it would look against the skirting boards and wall colour. The photo really doesn't capture how beautiful it is. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Seeing as we are doing our downstairs tiles after handover, we had to try pick a tile for our laundry and powder room that would work in with this tile. We ruled out doing a 600x600 porcelain tile as we knew the lay of the tiles wouldn't match up and this would trigger my OCD haha. So we decided to go with a smaller patterned tile that didn't look like it was trying to be married to the main floor tile. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The power room will have a feature wall tile which will be white brick lay subway tile from the floor to 1200mm high with a bullnose capping, like the powder room of the Marriott Grange display. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Instagram blog: https://www.instagram.com/ourforevertonhome/ Re: Building the Marriott 47 (Waldorf) by Porter Davis QLD 11Jan 13, 2018 6:13 pm Waldorf_Grange_Build lilbza The developers flat out said they wouldn't allow anything over 8.5m because it was a council regulation, so that was that. Bummer. Oh well the house will look amazing regardless. Our developer wouldn’t let us have the window bars. It’s annoying how strict they can be. Yeah I was quite surprised on just how much influence they can have on the appearance of your home. Instagram blog: https://www.instagram.com/ourforevertonhome/ Re: Building the Marriott 47 (Waldorf) by Porter Davis QLD 12Jan 14, 2018 9:22 am The floor/wall tile for all bathrooms will be a 600x600 porcelain tile. Ensuites 2,3 and 4 will have this tile on the floor, skirting, and shower, including the recessed niche. The master ensuite will have this tile done floor to ceiling on every wall, except the splash back feature wall. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Ensuites 2,3 and 4 we just went with the builders inclusion cat 1 300x100mm white subway tile in brick lay pattern for the splash back. In the master ensuite we used the same cat 1 white subway tile for the feature wall, however we did this in herringbone lay floor to ceiling. Our kitchen splash back we went with Bulevar grey 300x100mm subway tile in a brick lay pattern with white grout to compliment our white kitchen cabinetry. It has a ripple effect on the tile to give it a textured look, might be hard to see it in this photo. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Our terrace and front balcony tile is also in the photo above and is called Regina Charcoal. For bench tops throughout the entire house we chose lagoon, which seems to be a popular choice around this forum I've noticed. Instagram blog: https://www.instagram.com/ourforevertonhome/ Re: Building the Marriott 47 (Waldorf) by Porter Davis QLD 13Jan 14, 2018 1:30 pm lilbza The floor/wall tile for all bathrooms will be a 600x600 porcelain tile. Ensuites 2,3 and 4 will have this tile on the floor, skirting, and shower, including the recessed niche. The master ensuite will have this tile done floor to ceiling on every wall, except the splash back feature wall. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Ensuites 2,3 and 4 we just went with the builders inclusion cat 1 300x100mm white subway tile in brick lay pattern for the splash back. In the master ensuite we used the same cat 1 white subway tile for the feature wall, however we did this in herringbone lay floor to ceiling. Our kitchen splash back we went with Bulevar grey 300x100mm subway tile in a brick lay pattern with white grout to compliment our white kitchen cabinetry. It has a ripple effect on the tile to give it a textured look, might be hard to see it in this photo. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Our terrace and front balcony tile is also in the photo above and is called Regina Charcoal. For bench tops throughout the entire house we chose lagoon, which seems to be a popular choice around this forum I've noticed. Beautiful choices. The porcelain tiles will look stunning and lagoon benches throughout, wow. Re: Building the Marriott 47 (Waldorf) by Porter Davis QLD 14Jan 14, 2018 1:38 pm Waldorf_Grange_Build Beautiful choices. The porcelain tiles will look stunning and lagoon benches throughout, wow. Thank you. We really hope it all comes together how we have envisioned it... as you would know, it's hard to imagine everything on a large scale when working with such small samples. Instagram blog: https://www.instagram.com/ourforevertonhome/ Re: Building the Marriott 47 (Waldorf) by Porter Davis QLD 15Jan 14, 2018 1:45 pm lilbza Waldorf_Grange_Build Beautiful choices. The porcelain tiles will look stunning and lagoon benches throughout, wow. Thank you. We really hope it all comes together how we have envisioned it... as you would know, it's hard to imagine everything on a large scale when working with such small samples. Oh yes that’s the hardest part. Your samples look great together so I’m sure it will look stunning on a large scale. And your choices sound so opulent, real wow factor. Re: Building the Marriott 47 (Waldorf) by Porter Davis QLD 16Jan 14, 2018 2:38 pm Waldorf_Grange_Build lilbza Thank you. We really hope it all comes together how we have envisioned it... as you would know, it's hard to imagine everything on a large scale when working with such small samples. Oh yes that’s the hardest part. Your samples look great together so I’m sure it will look stunning on a large scale. And your choices sound so opulent, real wow factor. We really hope so too. We just can't wait to get to site now. We were booked in for a site start this month, but a few delays out of our control have pushed our site start back until March. If everything goes smoothly, we hope to be in before Christmas. Instagram blog: https://www.instagram.com/ourforevertonhome/ Re: Building the Marriott 47 (Waldorf) by Porter Davis QLD 17Jan 28, 2018 12:12 pm We got word on Friday that our land has now registered and settlement is due on the 8th of February. I also heard from PD and they have told us that to get developer approval, we are required to submit a landscaping plan for the front of the property before a building permit will be issued. Has anyone been required to submit a landscaping plan? Our developer requires us to have at least 5 plants, 1 pot 75L or greater and 1 tree. We also aren't allowed plain concrete driveways, so we have to list the material of the driveway on the landscaping plan. We are going exposed aggregate for the driveway, so that's no issue. PD said we can use our current site plan and edit it to add the landscaping we are doing. Can the landscaping be hand drawn and coloured in to show grass/plants etc? If not, does anyone know of a free landscaping program where I could scan our current site plan and make changes? Instagram blog: https://www.instagram.com/ourforevertonhome/ Re: Building the Marriott 47 (Waldorf) by Porter Davis QLD 18Jan 28, 2018 1:46 pm lilbza We got word on Friday that our land has now registered and settlement is due on the 8th of February. I also heard from PD and they have told us that to get developer approval, we are required to submit a landscaping plan for the front of the property before a building permit will be issued. Has anyone been required to submit a landscaping plan? Our developer requires us to have at least 5 plants, 1 pot 75L or greater and 1 tree. We also aren't allowed plain concrete driveways, so we have to list the material of the driveway on the landscaping plan. We are going exposed aggregate for the driveway, so that's no issue. PD said we can use our current site plan and edit it to add the landscaping we are doing. Can the landscaping be hand drawn and coloured in to show grass/plants etc? If not, does anyone know of a free landscaping program where I could scan our current site plan and make changes? Yes we had to submit a landscape plan to our developer too. You can hand draw them. Many people in our estate did. Just make sure everything is labeled and is in line with the guidelines your developer requires. We had to even include our letterbox. As far as I am aware no one in my estate has been forced to stick to the plan. And many changed their designs by the time their house was built and they landscaped. Re: Building the Marriott 47 (Waldorf) by Porter Davis QLD 19Jan 28, 2018 2:03 pm Waldorf_Grange_Build lilbza We got word on Friday that our land has now registered and settlement is due on the 8th of February. I also heard from PD and they have told us that to get developer approval, we are required to submit a landscaping plan for the front of the property before a building permit will be issued. Has anyone been required to submit a landscaping plan? Our developer requires us to have at least 5 plants, 1 pot 75L or greater and 1 tree. We also aren't allowed plain concrete driveways, so we have to list the material of the driveway on the landscaping plan. We are going exposed aggregate for the driveway, so that's no issue. PD said we can use our current site plan and edit it to add the landscaping we are doing. Can the landscaping be hand drawn and coloured in to show grass/plants etc? If not, does anyone know of a free landscaping program where I could scan our current site plan and make changes? Yes we had to submit a landscape plan to our developer too. You can hand draw them. Many people in our estate did. Just make sure everything is labeled and is in line with the guidelines your developer requires. We had to even include our letterbox. As far as I am aware no one in my estate has been forced to stick to the plan. And many changed their designs by the time their house was built and they landscaped. Ok great, thank you for the tips. Would you mind sharing your landscaping plan? Just curious to see the kind of detail that was required. Instagram blog: https://www.instagram.com/ourforevertonhome/ Re: Building the Marriott 47 (Waldorf) by Porter Davis QLD 20Jan 28, 2018 2:36 pm lilbza Waldorf_Grange_Build lilbza We got word on Friday that our land has now registered and settlement is due on the 8th of February. I also heard from PD and they have told us that to get developer approval, we are required to submit a landscaping plan for the front of the property before a building permit will be issued. Has anyone been required to submit a landscaping plan? Our developer requires us to have at least 5 plants, 1 pot 75L or greater and 1 tree. We also aren't allowed plain concrete driveways, so we have to list the material of the driveway on the landscaping plan. We are going exposed aggregate for the driveway, so that's no issue. PD said we can use our current site plan and edit it to add the landscaping we are doing. Can the landscaping be hand drawn and coloured in to show grass/plants etc? If not, does anyone know of a free landscaping program where I could scan our current site plan and make changes? Yes we had to submit a landscape plan to our developer too. You can hand draw them. Many people in our estate did. Just make sure everything is labeled and is in line with the guidelines your developer requires. We had to even include our letterbox. As far as I am aware no one in my estate has been forced to stick to the plan. And many changed their designs by the time their house was built and they landscaped. Ok great, thank you for the tips. Would you mind sharing your landscaping plan? Just curious to see the kind of detail that was required. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I have a friend who is a draughtsman so he drew this up for me. Not sure if the writing is clear in the picture. Three options 1 Ask the liquidator 2 Find another PD customer and ask the source of their report 3 Pay for new report 3 12320 Hi, I contracted a Builder to do a Garage to Bedroom + ensuite conversion (Class 1a), the Builder engaged the Certifier and Engineer and received BDA from the Certifier… 0 4996 Hi all. Anyone know when the $11,000 limit was set in legislation for renovations in QLD? Ive been renovating for 5 years now and this was the limit back then. As we know,… 0 4237 |
