Browse Forums Building A New House Re: Help ceiling expansion joint 4Nov 21, 2017 10:26 am jsesTAGE1B Check your Engineering drawings for expansion joints? Are you using steel framing? Not only does that look ugly it could possibly be incorrect (builders mistake?).. seek the engineers clarification Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Help ceiling expansion joint 5Nov 21, 2017 10:58 am Hi Thanks for your reply, I checked all my engineers reports and it isn't drawn in on any plans, do you know the maximum span before a expansion joint is needed ? Thanks Re: Help ceiling expansion joint 7Nov 21, 2017 7:25 pm jsesTAGE1B Sorry more questions Is it shown on your floor plans, construction details, anywhere? Is your roof framing trusses? How long is your passage? Expansions coefficients here Gyprock Engineering properties Control Joints page 30 Gyprock Installation guide Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Help ceiling expansion joint 8Nov 21, 2017 8:10 pm Hi Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Attached are our construction plans and also roof truss plan. I would say it is approx 7m from front door, it is the only visible ceiling join in the house. Your feedback is much appreciated I check over all plans today and it does not mention it anywhere. Help ceiling expansion joint 9Nov 22, 2017 6:07 am That is an awfully long run from the front door to the back of the living area (around 20m). Your builder is the one who provides you warranty, and sometimes they do something that was missed by designers and engineers. He probably thought it was warranted. No doubt if he didn’t put in an expansion joint, you would have concerns if after a year a crack appeared in a random place along that run length. He should have discussed it with you at some point to decide where to put an expansion joint, but I think including one is reasonable. Re: Help ceiling expansion joint 10Nov 22, 2017 7:32 am JsesTAGE1B Thanks for the info There is a need for a break in the ceiling but he could have placed &/or disguised it better Personally I wouldn't accept that. Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Hi, I am planning to select San Selmo reclaimed original for the fascade of my build. I have seen many photos on line of the brick varying from a rustic to a neat finish.… 0 4696 Hi guys, I want to butt a concrete vegetable garden bed against a concrete build up of a carport. It will be a 700mm high wall about 120mm thick and I will run a 12mm rio… 0 2792 Thank you @ashington Homes for your reply! They just got back to me and offered credit for me to just take it as is. It was a less than quotes I got from ceiling… 6 1739 |
