Browse Forums Building A New House Re: 2.7m ceiling height and garage door height... thoughts.. 31Nov 21, 2017 10:17 pm 2.4m is about 28c so will look good. The other to check if building 31c/2.7m is eve height. We have all eves at 28c/2.4m to avoid any spandral ends. Re: 2.7m ceiling height and garage door height... thoughts.. 33Nov 22, 2017 1:49 pm sabrelli Thanks all, i visited my site yesterday, and they have a string marking 2.4m so lucky!!one day later and it wouldve been too late!! @chrinee thanks a ton once again! have u amended your garage door height? No promblem. Serendipitous timing for my post then! Yes we have x Re: 2.7m ceiling height and garage door height... thoughts.. 34Dec 05, 2017 4:49 pm Re: 2.7m ceiling height and garage door height... thoughts.. 36Mar 30, 2018 9:06 am sabrelli Doulton777 sabrelli Thank you so much this topic! I totally forgot about increasing my garage door height!!!! ive already started building and hoping its not too late! If you upgraded your ceilings then they would asked you if you wanted your doors upgraded. If you said yes I believe that includes the garage internal door. That’s what we did and our garage door is 2300 I think. Ceiling height for ground floor is 2700. But definitely make sure it easy. Cos with builders you never know. my 2.7m ceilings were an upgrade and i wasnt asked if i wanted to raise internal doors or garage door. with my garage, ive got a 510mm drop from the kitchen so the standard garage height looks out of whack - see below! im surprised i didnt pick it up when going thru the plans! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Our construction plan looks different, and not written face bricks etc. is this your construction plan? we did not receive detailed like this. Re: 2.7m ceiling height and garage door height... thoughts.. 37Mar 30, 2018 9:34 am Kandi sabrelli my 2.7m ceilings were an upgrade and i wasnt asked if i wanted to raise internal doors or garage door. with my garage, ive got a 510mm drop from the kitchen so the standard garage height looks out of whack - see below! im surprised i didnt pick it up when going thru the plans! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Our construction plan looks different, and not written face bricks etc. is this your construction plan? we did not receive detailed like this. Yup, this is from my construction plans - and part of the documentation that was lodged to the council for DA approval. Unless the room is for storage then it's non compliant BCA V2 2019 S3 P3.8 You have 2 options 1. The builder deconstructs the section and rebuilds as per plan /… 7 10683 It sounds like you have a crack in your garage where the wall meets the ceiling, along the shadow line on the… 0 17195 i imagine you also have another contract with an architect? and yeah, whatever other's said about special conditions and appendices 16 16001 |
