Browse Forums Building A New House Re: 2.7m ceiling height and garage door height... thoughts.. 7Nov 18, 2017 12:00 am Thank you so much this topic! I totally forgot about increasing my garage door height!!!! ive already started building and hoping its not too late! Re: 2.7m ceiling height and garage door height... thoughts.. 8Nov 18, 2017 7:44 pm chrinee For those of you who opted to increase ceiling height to 2.7m, did you also upgrade your garage door height? Any pics to support your decision are appreciated. Renee x We designed our house to have 31c ceilings throughout including the garage and adjusted all external windows and doors to 28c including the garage door. Re: 2.7m ceiling height and garage door height... thoughts.. 9Nov 19, 2017 7:51 pm sabrelli Thank you so much this topic! I totally forgot about increasing my garage door height!!!! ive already started building and hoping its not too late! If you upgraded your ceilings then they would asked you if you wanted your doors upgraded. If you said yes I believe that includes the garage internal door. That’s what we did and our garage door is 2300 I think. Ceiling height for ground floor is 2700. But definitely make sure it easy. Cos with builders you never know. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ This is ours. We didn’t think about upgrading it. But that’s something that can be changed easy. viewtopic.php?t=86597 Re: 2.7m ceiling height and garage door height... thoughts.. 10Nov 19, 2017 8:04 pm Thanks Doulton777. We upgraded our ceiling to 2740mm during sales, but no one mentioned internal doors or the garage. It only came to mind when I read this forum. Thanks for feedback on your garage size. Re: 2.7m ceiling height and garage door height... thoughts.. 11Nov 19, 2017 8:06 pm chrinee Thanks Doulton777. We upgraded our ceiling to 2740mm during sales, but no one mentioned internal doors or the garage. It only came to mind when I read this forum. Thanks for feedback on your garage size. Anytime. Which stage are you at? viewtopic.php?t=86597 Re: 2.7m ceiling height and garage door height... thoughts.. 12Nov 19, 2017 8:44 pm Doulton777 sabrelli Thank you so much this topic! I totally forgot about increasing my garage door height!!!! ive already started building and hoping its not too late! If you upgraded your ceilings then they would asked you if you wanted your doors upgraded. If you said yes I believe that includes the garage internal door. That’s what we did and our garage door is 2300 I think. Ceiling height for ground floor is 2700. But definitely make sure it easy. Cos with builders you never know. my 2.7m ceilings were an upgrade and i wasnt asked if i wanted to raise internal doors or garage door. with my garage, ive got a 510mm drop from the kitchen so the standard garage height looks out of whack - see below! im surprised i didnt pick it up when going thru the plans! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: 2.7m ceiling height and garage door height... thoughts.. 13Nov 19, 2017 9:15 pm sabrelli Doulton777 sabrelli Thank you so much this topic! I totally forgot about increasing my garage door height!!!! ive already started building and hoping its not too late! If you upgraded your ceilings then they would asked you if you wanted your doors upgraded. If you said yes I believe that includes the garage internal door. That’s what we did and our garage door is 2300 I think. Ceiling height for ground floor is 2700. But definitely make sure it easy. Cos with builders you never know. my 2.7m ceilings were an upgrade and i wasnt asked if i wanted to raise internal doors or garage door. with my garage, ive got a 510mm drop from the kitchen so the standard garage height looks out of whack - see below! im surprised i didnt pick it up when going thru the plans! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I’m surprised they didn’t pick it up. Gee it does look out of whack. Do you know what your internal doors are now? viewtopic.php?t=86597 Re: 2.7m ceiling height and garage door height... thoughts.. 14Nov 19, 2017 9:21 pm Doulton777 I’m surprised they didn’t pick it up. Gee it does look out of whack. Do you know what your internal doors are now? viewtopic.php?t=86597 2.1m for all internal doors, with 2.3 for alfresco stacker. Sent an email to the builder to see if they can increase garage so its in line with top of entry door so hopefully shouldnt be a problem Re: 2.7m ceiling height and garage door height... thoughts.. 16Nov 19, 2017 9:24 pm Re: 2.7m ceiling height and garage door height... thoughts.. 17Nov 19, 2017 9:27 pm It doesn’t look too bad. I thought it would be way higher. Maybe they adjusted it? viewtopic.php?t=86597 Re: 2.7m ceiling height and garage door height... thoughts.. 18Nov 19, 2017 9:29 pm I don’t like your chances of them changing it now. I would be very surprised as that’s a structural change. viewtopic.php?t=86597 Re: 2.7m ceiling height and garage door height... thoughts.. 19Nov 19, 2017 9:35 pm Doulton777 I don’t like your chances of them changing it now. I would be very surprised as that’s a structural change. viewtopic.php?t=86597 I think i might be ok as they havent installed the t-bar lintel. Since its a parapet wall, im assuming all they need to do is reduce a few layers of brickwork and to order a larger roller door. Unless the room is for storage then it's non compliant BCA V2 2019 S3 P3.8 You have 2 options 1. The builder deconstructs the section and rebuilds as per plan /… 7 10665 It sounds like you have a crack in your garage where the wall meets the ceiling, along the shadow line on the… 0 17192 i imagine you also have another contract with an architect? and yeah, whatever other's said about special conditions and appendices 16 15980 |
