Browse Forums Flooring & Floor Covering Re: Vinyl Plank Flooring Questions Answered 36May 07, 2018 10:03 pm algernon Good vinyl planks do not contain phthalates (instead they use alternatives such as bio-plasticisers), nor any of the other controversial PVC additives. Look for vinyls which have independent environmental certification, e.g. EcoSpecifier GreenTag, etc. (which covers not just health and indoor air quality, but also overall environment impact) A good vinyl plank will have less VOC off-gassing than timber flooring (bearing in mind that wood naturally contains formaldehyde), and will use zero-VOC adhesives in its installation. Such products are readily available in Australia from several major suppliers (e.g. Karndean, Polyflor, Pegulan). Agree to that, do your own research. Formaldehyde is possible only in engineered wood (and laminates), not in hardwood, BTW (wood does not contain formaldehyde naturally but it is rather used in a plywood glue). Re: Vinyl Plank Flooring Questions Answered 38May 07, 2018 10:20 pm alexp79 Formaldehyde is possible only in engineered wood (and laminates), not in hardwood, BTW (wood does not contain formaldehyde naturally but it is rather used in a plywood glue). Sorry, but that statement is incorrect. Natural timber itself does contain measurable levels of formaldehyde. Engineered wood and laminates do indeed contain much more formaldehyde than pure natural timbers due to the bonding agents used. Within natural timbers, hardwoods typically contain less than softwoods, but they still contain (and off-gas) measurable levels of formaldehyde. Low levels, but not no levels. See, for example, the research paper "Wood-borne formaldehyde varying with species, wood grade, and cambial age", which goes into results for various different natural species and ages. Natural hardwood is low-VOC, but not zero-VOC. For those of us dealing with extreme chemical sensitivities, the difference can be very important. Re: Vinyl Plank Flooring Questions Answered 39May 07, 2018 10:31 pm steel alexp79 If your vinyl planks carry phthalates (as most of them do), you are not okay, because they off-gas. Most? The two products I am selecting between dont. https://www.ecocenter.org/healthy-stuff ... ss_release https://healthybuilding.net/news/2014/0 ... free-vinyl Also, keep in mind, only few green certifications are testing for phthalates when measuring off-gases, most of them don't. Re: Vinyl Plank Flooring Questions Answered 40May 07, 2018 10:42 pm algernon alexp79 Formaldehyde is possible only in engineered wood (and laminates), not in hardwood, BTW (wood does not contain formaldehyde naturally but it is rather used in a plywood glue). Sorry, but that statement is incorrect. Natural timber itself does contain measurable levels of formaldehyde. Engineered wood and laminates do indeed contain much more formaldehyde than pure natural timbers due to the bonding agents used. Within natural timbers, hardwoods typically contain less than softwoods, but they still contain (and off-gas) measurable levels of formaldehyde. Low levels, but not no levels. See, for example, the research paper "Wood-borne formaldehyde varying with species, wood grade, and cambial age", which goes into results for various different natural species and ages. Natural hardwood is low-VOC, but not zero-VOC. For those of us dealing with extreme chemical sensitivities, the difference can be very important. Interesting article. They have measured 0.15-0.7 mg/100g which is beyond the most stringent standards (E0 is <3 mg/100g, Japanese standard is <1.2mg/100 g). Most people can't smell formaldehyde at concentrations of 0.5 mg/100g or lower. Most of the kitchens and furniture are done to E1 standard (8 mg/100 g) those days, so hardwood wooden floor won't be the worst contributor. Hi l plan to install a self adhesive vinyl plank floor. l first need to attach masonite boards underlay to by plywood subfloor of my house. What size nails and how many… 0 8370 Levelling compound Ardit is the best but buy a bag of sand and make sand dam to protect your wood floor 2 15252 |
