Browse Forums Building A New House Re: Canberra custom KDR 16Nov 20, 2017 11:21 pm As expected due to the rain, Thursday was a washout, as was Friday. Then, today, this happened: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Ground floor frames are up! (Mostly, still a bit of finishing off to do). They seem pretty good to our inexpert eyes - generally square and flush, noggins throughout, no timber that we could see with big holes or other visible defects. Without measuring anything, the floor plan looks pretty right on first glance. It was an interesting experience walking around what feels like the first truly tangible signs of the house to be - the physical embodiment of the plans I'd spent so long working on and agonising over. For the first time I could see in full scale how the house works and how it interacts with the surroundings. I could check views from (future) windows, internal sight lines, distances and clearances, movement and flow in real life - fortunately, it's all working out well so far! (Not that that kept me from keeping on double-guessing the plan - should I have changed the window heights again? Should that display niche be deeper? etc. But on reflection and after the initial experience, I still think we've made the right calls). Re: Canberra custom KDR 17Nov 21, 2017 8:04 pm Looking good. It is a great feeling when you can see the house in the 'flesh' as it were. Keeping my fingers crossed for your roof prior to Christmas. Variegated Re: Canberra custom KDR 18Nov 23, 2017 10:20 pm As of yesterday - my precious Posistruts Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Locked together with strongbacks, these should form a very solid base for the upper floor, much sturdier than typical Australian construction. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Here's an overview of the site, showing the garage in front of the house (the garage looks a lot larger in proportion due to the camera angle and foreshortening, it's not really that big!): Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Mind you, there was a slight slip-up with the garage. We'd factored in the trees on our site, but it hadn't clicked that one of the neighbour's trees was overhanging the fence: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ A bit of trimming will be required! Re: Canberra custom KDR 19Dec 01, 2017 9:42 pm So, on Saturday the Hebel PowerFloor went on: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ And then yesterday the upper frames went up: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The roof trusses have been craned up, but won't be installed until after the Proctorwrap (it gets wrapped over the top plate and then the trusses get placed on top. We then had an official framing stage inspection today with the builder - a couple of minor things to do (which he was already aware of), but nothing major - the framing stage is essentially complete (and invoice issued). It was a very wet afternoon, but fortunately we were able to see the views from upstairs before the rain set in - and it's as good as we hoped for! Getting up on ladders, flying camera drones, and estimating from what you could see on the ground is one thing - being able to finally see it directly in person is very different (and very reassuring, in our case). The existing trees provide privacy from our neighbours' yard (which was a concern for both us and them), and we've got excellent views all-round otherwise. Re: Canberra custom KDR 20Dec 02, 2017 7:43 am Looking good! What function does the proctorwrap serve? Being able to see the view instead of imagining it is a great feeling, and I'm glad that yours has met expectations. Hope the current rain doesn't slow things down for you too much. Variegated Wow I hadn't realised things had gotten that pricey in just a couple of years since I built, that is crazy with how much land is now costing if you aren't lucky enough to… 3 5334 We were lucky in that our old house was so small (86 square metres) compared to the new house, they were able to take enough readings around the old backyard house before… 8 24713 The biggest challenge will be if you take out a loan and then run out of money - you'll have an incomplete security and lenders do not like this so you can get stuck.… 2 13453 |
