Browse Forums Building A New House Re: Low-E, Double Glazing, uPVC, Aluminium, U-values, SHGC 10Aug 12, 2017 1:13 pm ehhc Hi Ed, I can't find this config rated on the Wers website. Is there a way to work out the uW, SHGC? 1. Dowell thermaline 6.38mmCP Clear/14mm_argon/4mmClear (West 3.6m XOOX) That, plus below 2 glazing upgrades were not included the Nathers assessment, which defaulted to standard single glazed aluminum with uW:6.7 and SHGC:0.7. 2. Stacker 6.38CP (North 3.6m XOO) 3. Stacker 6.38CP (South 3.6m XOO) Would the above 3 make any improvement to our nathers rating? Thank you in advance! Hi I don't see any comfortplus in the Thermaline range. I don't know what this was replacing, so can't comment on improvement. Converting from single glazed to low-E shows as a significant improvement in WERS, but I think it is more in the numbers than reality. Thanks Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Low-E, Double Glazing, uPVC, Aluminium, U-values, SHGC 12Aug 12, 2017 2:41 pm Welcome. Not if it must be butt glazed. Is it out of the question to put a stud in the corner and have double glazed windows? Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Low-E, Double Glazing, uPVC, Aluminium, U-values, SHGC 14Aug 12, 2017 3:03 pm I assume you want to stop the solar heat gain (?), if so then you could put a corner louvre panel over the window at 90 deg. Depth say 1m. IYKWIM. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 For your reference Performance Labels: Window assemblies in housing, except timber windows, must be labelled so the label can be seen when it is in situ. For timber… 6 7733 This is one of the reasons I decided to go overseas for my double glazed windows. As the builder indicated, he's worked on many upmarket builds, these were the most well… 13 19256 I don't know them all, the first 2 top of your list are best known. Rylock is a good company, Stegbar is for sale. 4 16240 |
