Browse Forums General Discussion Re: FFL 200mm low 2Jul 18, 2017 10:16 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: FFL 200mm low 4Jul 18, 2017 7:27 pm Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: FFL 200mm low 6Jul 18, 2017 8:43 pm John3294 You have hit on the reason why some don't tell you when they start..they don't want anyone inspecting the work. You have to insist and even then some builders still don't tell you.They ignore Building Inspectors.. not so much structural engineers. Sorry to say the planning height guidelines are very weak to enforce after the event Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: FFL 200mm low 7Jul 18, 2017 8:55 pm John3294 Solutions can usually be found for the technical issues, at a cost, ..... A cynical person might also see that as an opportunity to make a lot extra post contract signing (see 2 above in my post) ? you will need to weigh up all the facts. I can't stress how important it is to ask questions, Take photos & always make informed decisions before the event Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs I am looking to design an entry door to a lower ground basement that has 2200mm between the external entry height to FFL of the ground floor. This door will provide an… 0 11370 4 6201 If you can calculate the reasonable charged head from let's say 100mm below the gutter to the top of where the vertical riser's horizontal discharge pipe will be, that… 11 17537 |
