Browse Forums Building Standards; Getting It Right! Re: Solar HWS not approved due to direction in Queensland 8Jul 24, 2017 1:26 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Solar HWS not approved due to direction in Queensland 10Jul 25, 2017 1:10 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Solar HWS not approved due to direction in Queensland 11Jul 25, 2017 2:33 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Solar HWS not approved due to direction in Queensland 13Jul 25, 2017 4:35 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Solar HWS not approved due to direction in Queensland 14Jul 26, 2017 10:10 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Solar HWS not approved due to direction in Queensland 16Jul 27, 2017 10:19 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Solar HWS not approved due to direction in Queensland 17Jul 27, 2017 12:58 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Solar HWS not approved due to direction in Queensland 18Aug 01, 2017 9:52 pm The plumbing inspector should stick to what he knows (plumbing) and leave the energy calculations up to those of us who understand solar design and thermodynamics... A solar system in Queensland only loses marginal performance by being outside ideal azimuth and orientation. And west north west is actually probably better for solar hot water because it's heating the water with the afternoon sun for the evening when you use most of your hot water... A little bit of knowledge can be dangerous with some people. Building Services Engineer Renovating our 1960's modernist home in Brisbane https://forum.homeone.com.au/viewtopic.php?f=53&t=82091 Assuming you've modelled the TB8, TB10, TB12, TB2 & J1 joists/LVLs there, it appears as per drawing to me. There maybe should be an additional J1 between TB10 and T12 if… 3 31850 Pls help! The black marks show where our outdoor entertaining area would be along side of house as we have an irregular backyard and want to make use of the side as… 0 4355 1 10489 |
