Browse Forums General Discussion Re: Timber cladding 3Oct 19, 2017 7:29 pm Follow our Arden Toulouse build at http://ardentoulouse.blogspot.com.au Re: Timber cladding 5Oct 20, 2017 1:47 pm Follow our Arden Toulouse build at http://ardentoulouse.blogspot.com.au Re: Timber cladding 7Oct 20, 2017 2:54 pm Follow our Arden Toulouse build at http://ardentoulouse.blogspot.com.au Re: Timber cladding 9Oct 20, 2017 3:17 pm Follow our Arden Toulouse build at http://ardentoulouse.blogspot.com.au Re: Timber cladding 11Oct 20, 2017 3:34 pm Follow our Arden Toulouse build at http://ardentoulouse.blogspot.com.au Re: Timber cladding 13Oct 21, 2017 1:25 am JessieNewie Hey JB1, the biowood looks good! I am also wanting to do castellation type cladding, but vertical. Do you have your own build thread? Iโm fairly new to homeone so my apologies if that is obvious and I just canโt find it ๐๐ Hi Jessie, No build thread yet because nothing has happened yet, but lots have been happening in the background. If you read my post, I'm also installing them vertically and the reasons why. I'm impressed with the biowood. I spoke to the distributor and have a sample of the product. Re: Timber cladding 15Oct 22, 2017 6:37 am I've used red ironbark from Queensland on my place. It is laid horizontally - shiplap join. The timber cost around $150/sqm. The idea is to have minimal maintenance and as such it will not be treated and should be good for 50 years plus. It will go a soft grey in due course which is not a problem for me. Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 15923 Standard uninsulated double brick has an R value of around 0.7. An insulated standard 90mm stud timber frame can have an R value of around 2.7. Even if you insulate a… 17 12069 The spacing of the studs looks pretty large especially for a load bearing wall. 3 11122 |
