Browse Forums Lighting + Lighting Design Re: Noob lighting questions! 2Jul 15, 2017 11:14 am Batten lights for everything that's not going to remain a down light. The batten is strengthening that anything heavy takes the weight. Personally hate 2 way switches. My OCD kicks in when down can be off or on.... Re: Noob lighting questions! 4Jul 15, 2017 10:40 pm Berek Batten lights for everything that's not going to remain a down light. The batten is strengthening that anything heavy takes the weight. Personally hate 2 way switches. My OCD kicks in when down can be off or on.... thanks berek, so that means the chandeliers and track lighting should be batten points right? My build blog here Re: Noob lighting questions! 6Jul 21, 2017 9:33 am Stick with batten lights where it's going to be replaced with something else post handover. It's cheaper to get a standard batten light than a Led downlight. Also if any of the pendant or statement pieces are going to be big and heavy. Request to have noggins put in to support the light. My KDR Metricon Hampshire - Liberty - 45 Melb https://r.tapatalk.com/shareLink?share_ ... are_type=t Re: Noob lighting questions! 9Sep 03, 2017 2:35 pm Buildingourfirstnest Thanks Renman. Would you know anything about roof access to the ground floor fixtures if there is no second floor on them (as per my plans)? Once the plaster is up there's access from the ground floor. My KDR Metricon Hampshire - Liberty - 45 Melb https://r.tapatalk.com/shareLink?share_ ... are_type=t Re: Noob lighting questions! 10Oct 01, 2017 1:04 pm Buildingourfirstnest If I only did prewiring for a fan and not a light, will the sparky be able to do install a fan and light combo? Building a Clarendon Ferndale MK II No as it would require a extra core to switch the light separately. Depending on the construction of the home either being brick or plasterboard walls. Brick: requires a conduit to install a extra core to existing switch unless the existing switch has enough cores to rewire to suit. Plasterboard: Can be done as you can probably use existing wires as draw wire to install extra core. Example: Toilet 1 x light & switch (Most builders do this if the toilet does not have a window), you can install an exhaust fan and have this separately switched using a switch multiplier if you can not get to the switch to add wires. It converts the existing wiring to 2 switches though relays. Switch multiplier: http://updates.clipsal.com/ClipsalOnline/Files/Brochures/W0001492.pdf _____________________________________ Building in Bedfordale Perth WA https://forum.homeone.com.au/viewtopic.php?f=31&t=89716 Churchman Brook Electrical Services EC 8659 Re: Noob lighting questions! 11Oct 02, 2017 12:56 pm Judging by the drawing you posted, it seems there will be access in this ground floor area of your ceiling (that is if a man hole is installed for this area) It may be worth asking your builder if a man hole can be installed, as it will likely come in useful down the track when wanting to do work on your home. Even if the house has plaster walls, a draw wire may not be possible due to cables being clipped on timbers during rough in. If there is no ceiling access after handover in downstairs area, I would strongly suggest having noggins installed in ceiling where you intent on installing chandeliers or pendant lighting that may be quite heavy, as it may not be possible to install these weight bearing timbers without cutting holes in your plaster. (Not always the case but saves any surprises later). Also as others have suggested, battens should be installed for any light point that is to be upgraded after hand over, as a downlight will leave a much larger hole and will limit what fixtures can be installed later. Re: Noob lighting questions! 12Oct 02, 2017 2:49 pm LiamMcCrink Judging by the drawing you posted, it seems there will be access in this ground floor area of your ceiling (that is if a man hole is installed for this area) It may be worth asking your builder if a man hole can be installed, as it will likely come in useful down the track when wanting to do work on your home. Even if the house has plaster walls, a draw wire may not be possible due to cables being clipped on timbers during rough in. If there is no ceiling access after handover in downstairs area, I would strongly suggest having noggins installed in ceiling where you intent on installing chandeliers or pendant lighting that may be quite heavy, as it may not be possible to install these weight bearing timbers without cutting holes in your plaster. (Not always the case but saves any surprises later). Also as others have suggested, battens should be installed for any light point that is to be upgraded after hand over, as a downlight will leave a much larger hole and will limit what fixtures can be installed later. Thanks Liam! I've asked the builder and they have refused to install a manhole as I've already sign the building contract :/ So I'll probably have to think of cutting it out after handover if I want to do work on the house. My build blog here Building Standards; Getting It Right! 1. optional, you can but normally just use the earth from the main switch board 2. should be enough but the distance determines voltage drop - sparky should work it… 1 22115 I have a really long hallway which is 1100mm W x 11500mm L I would appreciate if anyone can give suggestions to light it up with Linear LED lights that goes from wall to… 0 5605 What? It's a lighting question, the control joint is only needed at 12m centres, a bulkhead or change of direction will suffice as a 'break' in the ceiling, just make… 8 5875 |
