Browse Forums General Discussion Re: House side concrete drainage 2May 21, 2017 12:49 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: House side concrete drainage 4May 21, 2017 8:00 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: House side concrete drainage 6May 22, 2017 1:32 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: House side concrete drainage 7May 23, 2017 10:21 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: House side concrete drainage 9May 26, 2017 1:27 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: House side concrete drainage 10May 27, 2017 7:45 pm SaveH2O Just another point if you do have the concreting redone. You will notice that there is no expansion foam between the path and the two walls. Using an expansion foam strip between the concrete path and the bricks is not a regulatory requirement as far as I know but it is best practice as it not only allows for expansion and stops cracking, it also prevents the concrete sticking to the bricks...something that will most likely be evident if the concrete is removed. There is a tear away strip on top of expansion foam that should be removed and a suitable flexible weatherproof sealant applied once the path has settled. This is not always done! Save H2O Thanks for your great posts. I learn so much by lurking on H1. I only had the flexible sealant added on top of expansion foam by concreter because of one of your earlier posts. My concreter said he has not done this before! And has been in the industry for many many years. ORG - I've had 3 plumbers out on the 5 months since I moved into the property and they state better if be compliant with ORG being below lowest waste in the house if can't comply with both measurements in landscaping esp if concreting with good slope away from ORG/house. And that VBA inspection of one of plumber's jobs required that ORG height be lowered to ground to comply with measurement below internal floor waste. Re: weep holes - that's a whole other story we didn't discuss as my house is made of Hebel. Re: House side concrete drainage 11May 27, 2017 10:27 pm Plumbing is a self regulated industry and plumbers sign off on their own work. There is endemic non compliance. Concreting is a notorious hit and miss industry with many cowboys. Combine the two and you can end up with potentially very bad situations that most trusting home owners are oblivious to. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Hi HomeOne, I'm in the midst of landscaping a cat run down the side of my house, and the recent rains have me wondering if I need to install some sort of drainage. I've… 0 12288 13 6632 Thanks for the photos. You need to know whether the inflow or the overflow pipe is leaking and this is a simple process of elimination. INFLOW: The vertical riser… 4 4683 |
