Browse Forums General Discussion 1 May 16, 2017 8:51 pm Building the Denver by Metricon on acreage Land settlement: 24/8/15 Contracts: 8/7/16 Finance approved: 5/8/16 Council approval.....? viewtopic.php?f=31&t=79213 Re: Quality of render finish 2May 16, 2017 9:48 pm M Y C U S T O M C O R A L B R O N T E 43 ...............Kitchen! 16 Nov 2016 https://forum.homeone.com.au/viewtopic.php?f=31&t=79581 Re: Quality of render finish 4May 17, 2017 12:16 am Our Bayside KDR Thread: viewtopic.php?f=31&t=78298 Re: Quality of render finish 5May 17, 2017 3:35 am MrsJM Out of curiosity how are the edges? On ours you can see the plastic stuff they run up the edge of the brickwork to square it off. Do you know what product they used? We have rockcote. Finish is horrid. I wouldn't think yours is acceptable either. C U S T O M. C O R A L. B R O N T E. 43 http://forum.homeone.com.au/viewtopic.php?t=79581 It's the Dulux acrylic render. Name escapes me at the moment, but comes pre tinted for the top coat. Edges looked good from the quick glance I gave it - I literally didn't look closely as the flooring guy's drop saw was set up on the portico. But this bit stood out like a sore thumb. Also, I saw them putting the base coat on and they used metal corners, not plastic. Building the Denver by Metricon on acreage Land settlement: 24/8/15 Contracts: 8/7/16 Finance approved: 5/8/16 Council approval.....? viewtopic.php?f=31&t=79213 Re: Quality of render finish 6May 17, 2017 3:37 am Drew01 Not a good enough finish in my books... If it shows in a photo, then it stands to reason it's worse to the naked eye Probably only needs another coat and will be set Much worse to the eye. The light was bouncing around and making it hard for my phone camera to pick it up. I'll make sure the SM gets someone in to add another coat. Would they need to add another coat all over or just to this pillar? Building the Denver by Metricon on acreage Land settlement: 24/8/15 Contracts: 8/7/16 Finance approved: 5/8/16 Council approval.....? viewtopic.php?f=31&t=79213 Re: Quality of render finish 7May 17, 2017 8:21 am Whatever the result - you SHOULD highlight it - ie get it on paper ! It should be done properly. Re: Quality of render finish 8May 17, 2017 9:57 am bubblynutter Drew01 Not a good enough finish in my books... If it shows in a photo, then it stands to reason it's worse to the naked eye Probably only needs another coat and will be set Much worse to the eye. The light was bouncing around and making it hard for my phone camera to pick it up. I'll make sure the SM gets someone in to add another coat. Would they need to add another coat all over or just to this pillar? Depends if it's just the pillar you're not happy with... Our Bayside KDR Thread: viewtopic.php?f=31&t=78298 Re: Quality of render finish 10May 17, 2017 9:16 pm My render issue is with blemishes appearing although I don't see mortar lines in mine I might change the color to dark Grey like my down pipes and that way nothing can be seen it all matters how it looks to the eyes .... Re: Quality of render finish 11May 22, 2017 7:01 pm Thanks for the feedback. We have PCI on Thursday so we will see what the Site Manager will do about it. I'm thinking they will paint it. Building the Denver by Metricon on acreage Land settlement: 24/8/15 Contracts: 8/7/16 Finance approved: 5/8/16 Council approval.....? viewtopic.php?f=31&t=79213 Re: Quality of render finish 12Jun 20, 2017 8:20 am It was 100% agreed to be a defect but the company has yet to come back and fix it, 2.5 weeks after handover... site manager is dealing with it. Building the Denver by Metricon on acreage Land settlement: 24/8/15 Contracts: 8/7/16 Finance approved: 5/8/16 Council approval.....? viewtopic.php?f=31&t=79213 Re: Quality of render finish 13Jun 21, 2017 5:28 am arcadelt White plastic edges will always be visible unless you paint. However, they are there for a reason - to protect the edges and then the render along the wall. If they didn't use them, a corner can easily chip and then that can chip can carry on along the rest of the wall. Exactly Building Standards; Getting It Right! But they didn't even leave it at one level it goes up and down along the whole front of the house 4 10949 4 14468 Hi Alex, Thanks for the reply again. I had a chat with the builder, he said he will use primer, then hydrotec which comes with colour and sealer as well. A Renderer I… 12 18102 |
