Browse Forums Building A New House Re: Recessed sliding door tracks 3Apr 20, 2017 11:26 pm ~Shellby~ GJ Bridgewater 203 11/3/2016 - Site Work Started 29/9/2016 - Handover 142 Work Days 6 Work Days Over https://forum.homeone.com.au/viewtopic.php?f=31&t=80174 Re: Recessed sliding door tracks 5Apr 21, 2017 9:22 am ~Shellby~ GJ Bridgewater 203 11/3/2016 - Site Work Started 29/9/2016 - Handover 142 Work Days 6 Work Days Over https://forum.homeone.com.au/viewtopic.php?f=31&t=80174 Re: Recessed sliding door tracks 11Apr 21, 2017 9:04 pm ~Shellby~ GJ Bridgewater 203 11/3/2016 - Site Work Started 29/9/2016 - Handover 142 Work Days 6 Work Days Over https://forum.homeone.com.au/viewtopic.php?f=31&t=80174 Re: Recessed sliding door tracks 13Apr 22, 2017 12:59 am Thanks guys. It gives me an idea of what the going rates are and I can at least use someone else's actual cost to argue prices if I think they're trying to take advantage. Re: Recessed sliding door tracks 14Apr 22, 2017 12:59 am Zee05 I was quoted $1 238 per recessed track!!!! Same builder with you Shelby and CB Wowza! That's ridiculous! I'm guessing you didn't recess your tracks then? Re: Recessed sliding door tracks 16Apr 22, 2017 7:17 am Zee05 definitely not!!!!which was a disappointment I can imagine. There are so many things we wanted for our build, but slowly over the past couple of weeks our list of wants have dwindled. Either it won't be worth the cost, or it won't be worth the fight. Who thought building a home with inclusions you want would be so difficult? Re: Recessed sliding door tracks 17Apr 22, 2017 7:32 am Anyone got photos on bow it's done? Is it done at slab prep stage? How many mm recessed is it? My timber flooring will be approx 25mm thick (above slab). My concern is water pooling if recessed too much and getting the position wrong at slab prep stage. Re: Recessed sliding door tracks 18Apr 22, 2017 7:52 am Zee05 I was quoted $1 238 per recessed track!!!! Same builder with you Shelby and CB Holy smokes!!! That's beyond a joke!! Do you have a thread I can follow? Like to follow GJ builds, not too many of us on here GJ Gardner Modified Coolum 277 http://forum.homeone.com.au/viewtopic.php?t=83643 Recessed sliding door tracks 19Apr 22, 2017 8:16 am JB1 Anyone got photos on bow it's done? My photos would not help you understand the process as it is being done in stages. JB1 Is it done at slab prep stage? Ours was, but for those where they just cut the slab afterwards, it would not be. JB1 How many mm recessed is it? To get a perfectly flush finish, it has to be recessed the thickness of the frame step + the thickness of any packing + the thickness of any flashing and/or waterproofing material + the thickness of floor coverings. JB1 My timber flooring will be approx 25mm thick (above slab). That will need to be accounted for. By the way, unless your timber is being fixed directly to the slab, the thickness may be greater to account for battens and/or deadening material. Depends on whether it's real timber or laminate. JB1 My concern is water pooling if recessed too much and getting the position wrong at slab prep stage. You should be concerned about water damage. Unless correctly planned for, water can sneak under the frame and leak into the house and damage your timber. Getting the position wrong is avoided by sound planning and then adjustment during installation. Of course, it would be easier if it is just cut into the slab, but even then floor coverings need to be considered unless it's just the slab inside. Re: Recessed sliding door tracks 20Apr 22, 2017 9:28 am charlibear Zee05 I was quoted $1 238 per recessed track!!!! Same builder with you Shelby and CB Holy smokes!!! That's beyond a joke!! Do you have a thread I can follow? Like to follow GJ builds, not too many of us on here GJ Gardner Modified Coolum 277 http://forum.homeone.com.au/viewtopic.php?t=83643 I’m in a similar position except I’m after sliding 3 stacking doors. I am on a second-story apartment of which the balcony would not adequately fit any bi-fold or… 5 16164 DIY, Home Maintenance & Repair Thanks Chippy . Did also see a YouTube video before. Removed them . Thanks again for the advice. 2 13964 |
