Browse Forums Building A New House Re: Metricon Savannah 34 - Kitchen & Pantry Cabinetry Is In. 167Jun 27, 2017 10:39 am Cheers Nom Newhaven 36 by M Blog - North Shore Newhaven (http://nsnewhaven.blogspot.com.au) Build - https://forum.homeone.com.au/viewtopic.php?f=31&t=85092 Re: Metricon Savannah 34 - Kitchen & Pantry Cabinetry Is In. 171Jun 27, 2017 10:15 pm My Phoenix by Metricon in Melbourne viewtopic.php?f=31&t=83584&p=1570829&hilit=my+phoenix+by+metricon+in+melbourne#p1570829 Re: Metricon Savannah 34 - Kitchen & Pantry Cabinetry Is In. 175Jun 29, 2017 9:33 am jasonwg They're really nice ... but expensive! I've got them through my kitchen, the only cat 9 upgrade I got in my whole home and cost $1k just for handles, it's a sleek look though! Please, don't remind me. Haha! It does look great though. Re: Metricon Savannah 34 - Kitchen & Pantry Cabinetry Is In. 176Jun 29, 2017 8:48 pm firejack018 nomnomnom Looking great! We got sharknosing too. It's only available on the 2 pack from memory. Firejack - could I ask a favour... can you open the bottom draws and tell me if there is a tiny metal L bar on the inside of the draw at the centre? For some reason they've installed all the little bars on the inside of my draws rather than on the underside of the draw which seems wrong to me. Also can you photograph how many screws they put in underneath? The railings have holes for a number of screws but it seems the cabinet maker on mine has put in a bare minimum of two on either side. The draws are supposed to hold 30 kg so I was hoping for more than just 2 little screws either side. Or maybe I'm just being paranoid having had ikea stuff for so long! lol Ok Nom. Here's the info you were after. All of the bottom drawers have the metal L bar on the inside centre position. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ All the other drawers have the metal L bar on the underside of the drawer: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ And you can see the screws in the above pic; they've used 1 screw in each section of bracket attached to to the drawer. And the runner brackets have four screws in each bracket. As seen below: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hope that helps. Thanks Firejack, you're a legend! Interestingly that's exactly the same as what they've done at mine. I guess that's the way they do it. Still seems odd the L bracket is internal on the bottom draws since I would have thought the bracket needs to support the draw from underneath. Only reason I can see why it's inside is if it catches on the bottom. Cheers Nom Newhaven 36 by M Blog - North Shore Newhaven (http://nsnewhaven.blogspot.com.au) Build - https://forum.homeone.com.au/viewtopic.php?f=31&t=85092 Re: Metricon Savannah 34 - Kitchen & Pantry Cabinetry Is In. 178Jun 30, 2017 7:52 pm nomnomnom Thanks Firejack, you're a legend! Interestingly that's exactly the same as what they've done at mine. I guess that's the way they do it. Still seems odd the L bracket is internal on the bottom draws since I would have thought the bracket needs to support the draw from underneath. Only reason I can see why it's inside is if it catches on the bottom. Heya no problem Nom. Yeah it's a bit annoying, as the holes are there anyway so why not use them right? Surely it's only going to make the drawer stronger by adding a couple more screws. Re: Metricon Savannah 34 - Kitchen & Pantry Cabinetry Is In. 179Jun 30, 2017 8:16 pm So there's been some more progress on the house. First up, the laundry and bathrooms have cabinetry installed. Here's the laundry in standard Burnished Wood finish: Here's the laundry in standard Burnished Wood finish:Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Our ensuite which is Contour Fine Edge finish in Polar White: Our ensuite which is Contour Fine Edge finish in Polar White:Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Our daughter's ensuite. Again it's Contour Fine Edge finish in Polar White: Our daughter's ensuite. Again it's Contour Fine Edge finish in Polar White:Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Boy's Bathroom which was supposed to be Contour Fine Edge with Burnished Wood, but the sub-contractors mucked it up and put Polar White instead: Boy's Bathroom which was supposed to be Contour Fine Edge with Burnished Wood, but the sub-contractors mucked it up and put Polar White instead:Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ And there's been some Doors, Architraves and Skirting Boards installed also. Here's the Home Theater sliding doors. They'll be stained in a dark charcoal finish. And there'll be some light-blocking curtains inside the doors to blackout the room: Here's the Home Theater sliding doors. They'll be stained in a dark charcoal finish. And there'll be some light-blocking curtains inside the doors to blackout the room:Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Sliding door to Butler's Pantry: Sliding door to Butler's Pantry:Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Sliding door to Butler's Pantry:Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Metricon Savannah 34 - More Cabinetry... 180Jul 16, 2017 1:55 am Ok it's been a while between posts, so it's high time for another walkthrough. Quite a lot has happened, and there's been quite a few stuff-ups as well. I'm waiting to see how Metricon handles the problems before I form any opinions. And onward we go... Tiling in the Portico. And a fan and light pre-wire added to carport. The electricians missed the ceiling power point for a future automatic lift-panel door.Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Closer look at the Portico.Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Electricity Box in.Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Gas Meter in.Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Entry Hall. That's just an undercoat on the LHS wall.Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Around the side through the Laundry entry.Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Laundry from the inside looking out.Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ My Gym at the front of the house. There's our Decina Mintori Freestanding Spa Bath. Woohoo!Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Our Roca toilets in my Music Room.Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Roca The GAP. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hi, First of all, thank you to this community for sharing your thoughts and opinions. We are in early days of our pre-contract stage for Metricon Doulton and we are… 0 10759 Hello All 🙂 We are planning to start our journey of construction our first home. We zeroed down on Metricon and henley homes based on design suitable for our lot and… 0 8205 We don’t live in VIC so want to know the exterior colours of Lumiere display so we can see it at the paint shop. Not building with Metricon so my request went… 0 17335 |
