Browse Forums Building A New House Re: Building with mojo homes 28Jul 31, 2017 10:03 pm Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Internal lining done and next will be doors I think followed by stairs and kitchen. PCI is expected in October. Re: Building with mojo homes 30Aug 01, 2017 10:28 am Hi I am selecting Hebel in my tender and want to know more about this material beforehand.I just read a article about the pros and cons about Hebel. the website: http://www.wabca.com.au/blog/pros-and-cons-of-hebel-wall-panels, here are part of their comments of the cons.
The other question, what is the thickness of Hebel, 20mm? is it good to retain heat/cool compare with brick? What do you think about this article,especially the joint movement, render crack and maintenance. Thanks Re: Building with mojo homes 31Aug 01, 2017 8:46 pm SearchingTim Hi I am selecting Hebel in my tender and want to know more about this material beforehand.I just read a article about the pros and cons about Hebel. the website: http://www.wabca.com.au/blog/pros-and-cons-of-hebel-wall-panels, here are part of their comments of the cons.
The other question, what is the thickness of Hebel, 20mm? is it good to retain heat/cool compare with brick? What do you think about this article,especially the joint movement, render crack and maintenance. Thanks 1) thickness is 75mm 2) maximum span is 6m. They have an expressed joint horizontally and veritcally. See pictures 3) hebel is a better insulator than brick. It retains less heat.. known fact.. 4) wrapped and delivery On my project the subbies rejected half the hebel on the truck because 2 panels were cracked. They said not worth the risk. New materials came the next day. If the panel is slightly bowed once fixed and rendered you will never know! And will have no effect on the finish. The on site installers dont pay for the hebel so they take no risk.. 5) as with any rendered house it will need maintenance. Pressure wash and eventually repainting. Which actually gives you a fresh new look!!! If you get a chance go to hillview rd. Drive around the estate. Theres a finished mojo at the start of the road. Theres on on watheroo and one on the next street down. Done in brick.. nice house but you geg lost in all the brickwork. Its an enigma 46 with 3rd garage Theres also a metricon being done now with hebel. If you go saturday i dare say theyd still be there installing! Also see pictures of expansion joints.. backing rod and caulked over to be painted Theres also one of a repair due to scaffolders.. once rendered youd never know Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Building with mojo homes 32Aug 02, 2017 8:38 am Hi James, thanks for your explanation, no questions now. I will take a look on the Hebel buildings there. when the Hebel comes to the site, I better there to see the Hebel quality and how they select the good and bad ones. Re: Building with mojo homes 34Aug 02, 2017 7:04 pm Hi, I have a question about Hebel if someone can help me? On a single story home is it easy for someone to kick or use a hammer to gain entry to the home? I've only ever had brick homes and the builder we are looking at uses hebel instead. Appreciate any feedback and information. Re: Building with mojo homes 35Aug 02, 2017 7:34 pm bee1980 Hi, I have a question about Hebel if someone can help me? On a single story home is it easy for someone to kick or use a hammer to gain entry to the home? I've only ever had brick homes and the builder we are looking at uses hebel instead. Appreciate any feedback and information. Possible but crazy. Top hats/services/wall wrap/framing all in the way There are weaker points of entry. The other thing is that once rendered a would be thief doesnt know if its rendered brick/clad or hebel. Its just a wall. Windows, Sliding doors and roof tiles are much easier to get through.. some people go colourbond for this reason! Re: Building with mojo homes 36Aug 06, 2017 3:21 pm We are now at lockout stage! Soul 40The roller door and front door are installed- we are at lockout stage nowLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Enty doorwe went with the double glazed glass on our door.Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Our indoor door choiceThese doors are much higher than what we currently have in our apartment. Makes the rooms look bigger!Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Building with mojo homes 37Aug 06, 2017 3:27 pm ja-mez bee1980 Hi, I have a question about Hebel if someone can help me? On a single story home is it easy for someone to kick or use a hammer to gain entry to the home? I've only ever had brick homes and the builder we are looking at uses hebel instead. Appreciate any feedback and information. Not easy at all Possible but crazy. Top hats/services/wall wrap/framing all in the way There are weaker points of entry. The other thing is that once rendered a would be thief doesnt know if its rendered brick/clad or hebel. Its just a wall. Windows, Sliding doors and roof tiles are much easier to get through.. some people go colourbond for this reason! the Hebel has a steel mesh so even if someone hammers there way through the concrete the steel mesh will prevent them form gaining access. Re: Building with mojo homes 38Aug 06, 2017 3:32 pm ja-mez Thats awesome!! Are you getting fancy stairs done? Thought they do stairs prior to lining.. no Fancy stairs for us mate. The free standing option was crazy expensive (around 25k)! We are better off spending that money on driveway and landscaping. You are right they usually do stairs before lining but in our case we have reached lockout and still no stairs! The SS is trying to get them in earlier instead of the scheduled 17th august. I can see your house is coming along quite well. What stage are you at right now? Have you got any quotes yet for things like fencing, driveway and landscaping? Re: Building with mojo homes 39Aug 06, 2017 10:06 pm Nabrolkellyville ja-mez Thats awesome!! Are you getting fancy stairs done? Thought they do stairs prior to lining.. no Fancy stairs for us mate. The free standing option was crazy expensive (around 25k)! We are better off spending that money on driveway and landscaping. You are right they usually do stairs before lining but in our case we have reached lockout and still no stairs! The SS is trying to get them in earlier instead of the scheduled 17th august. I can see your house is coming along quite well. What stage are you at right now? Have you got any quotes yet for things like fencing, driveway and landscaping? Handful of defects/incomplete works mean i probably wont get to lining by september. We have 4 weeks in august but theres 2- 3 weeks in exterior works and theres a couple issues which means that the scaffold wont come down so the lower roof wont get done. Knock on effect. No linings or electrical rough in until this is all closed out! Hoping our stairs go in early on as our tiles are huge. Be a nightmare taking that up a ladder! Havent had landscaping quotes as I'll be doing that myself. I find landscapers so hit and miss. You see ones worth every dollar and others that should stick to digging holes. Driveway my brother inlaw is a concrete so as you can imagine I'll be calling in a favour Is anyone building with Mojo and have a recent site cost tender 0 15954 Hi all, We are considering Enigma 46 from Mojo Homes in Gables, NSW. Has anyone built with Mojo and any pointers and feedback. Also, if anyone has built similar design… 0 13169 Hi, We are looking for a builder that can build a small home (smaller length) on a sloping site. We came across Mojo's Zephyr design 10.6 m wide and 11.5 m length. Does… 0 23029 |
