Browse Forums Heating, Cooling & Insulation 1 Aug 28, 2016 9:20 am hi...our ceilings are 3 metres and we are putting in Mercator Grange 1300mm fans which are 309mm from ceiling to bottom of fan. That leaves about 2.7m from the floor to blades so I'm wondering if I should use an extension rod? Any advice? Re: Ceiling fan extension rods 2Sep 24, 2016 1:26 am We have ceilings of a similar height and were advised to use a rod to have the fan sit 2.4-2.5m above the floor. Our electrician installed them at 2.4m, he said they looked a little too high at 2.5m. I think now they look a little low but I guess it's better for cooling than at the higher height. Re: Ceiling fan extension rods 3Oct 14, 2016 8:25 pm I looked into this a bit too, found it difficult to find much info but what I did eventually find said around 2400mm. Our ceilings are 2700mm so this works out perfectly without an extension rod. Re: Ceiling fan extension rods 4Oct 23, 2016 9:23 am Generally extension rods come in 300mm(standard), 600mm, 900mm and 1200mm. In your case I would suggest the 600mm so your fans are at 2400 but they will still work fine at 2700. Building Services Engineer Renovating our 1960's modernist home in Brisbane https://forum.homeone.com.au/viewtopic.php?f=53&t=82091 Any electricians here please help. 1) Will the Fan need separate switch to ON/OFF/Speed eventhough it comes with Remote 2) how about… 0 1228 My home office is hot with computer equipment running virtually 18 hours a day. When it gets unbearably warm I simply step out of my door into the living area which is… 0 5132 Hi, We have a single story MacDonald Jones house, on a waffle pod slab with steel frame. Are we able to build a second story extension? Other info is we are 900mm from… 0 8505 |
