Browse Forums Landscape & Garden Design Re: Stone retaining wall - advice needed 3Apr 25, 2016 9:02 pm Beetaloo If most of the stones are 300mm to 500mm then I would build a dry stone wall with the face of the wall leaning back. This will improve the stability of the wall and the gaps between the stones will allow water to seep through reducing hydrostatic pressure on the wall. If using mortar, a reinforced foundation may be required to prevent cracking also consider the colour of the mortar. A mortar using only cement and sand may look too dark. Try building a test wall using a lime/cement/sand mixture, for example try 2 parts lime, 1 part cement and 9 parts sand. Thanks for the advice - would you still put in agi pipe drainage or rely on allowing the water to seep through? Also, if doing a dry wall without mortar as you suggested what sort of base would you use? Re: Stone retaining wall - advice needed 4Nov 14, 2016 8:18 pm Hi, just bumping this thread again. I have decided to go with a dry stack wall as I have found enough large rocks to do the job. I have read many varying opinions on whether drainage is needed being a porous wall - some say none, some say aggregate only behind the wall, others say full aggregate and agi-pipe drain. What do you guys think, or what has your experience been? Hi All, I engaged a tradie to install concrete retaining wall 600-800mm high over 32 meters in Victoria. Sleepers are 200*75*2000 mm installed over 17 steel posts. I… 0 6889 Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 15648 Can anyone recommend a good/affordable retaining wall and fence builder that I can get a quote from located in Sydney? 8 45705 |
