Browse Forums DIY, Home Maintenance & Repair Re: Internal data wiring repair - Telstra Velocity 9Mar 08, 2016 7:25 am Saint Mike Telstra I mean It wouldn't be Telstra because box to Telstra is perfect. I am able to connect straight through but not through data sockets in the house, which supposedly powered by the box. So something is missing between the box and data sockets in the house, so it would be Internal and not Telstra. Re: Internal data wiring repair - Telstra Velocity 10Mar 08, 2016 2:44 pm OK ... who installed it ? You should know this. Have their details etc. Surely they can test the lines. Re: Internal data wiring repair - Telstra Velocity 11Mar 08, 2016 2:47 pm Saint Mike OK ... who installed it ? You should know this. Have their details etc. Surely they can test the lines. Yes, Metricon (Vaccaro Group). Do you know how many years warranty Metricon has on electrical (cabling/wiring) ? Re: Internal data wiring repair - Telstra Velocity 12Mar 08, 2016 2:48 pm No idea. BUT - they would have had someone do the smart wiring - not just any electrician. So they will know. Even if its out of warranty you have to get it checked. Re: Internal data wiring repair - Telstra Velocity 13Mar 08, 2016 2:52 pm Saint Mike Even if its out of warranty you have to get it checked. I'm currently checking with Metricon if it's still covered under warranty. For the mean time, I'm looking for my backup plan. @Saint Mike, you're in Sydney? if so, can you recommend a name? Re: Internal data wiring repair - Telstra Velocity 14Mar 08, 2016 2:55 pm No - Qld. I don't know the time frame you're talking about - but I'd wait for Metricon - it might be free and they should know who did it. Has it ever worked ? Re: Internal data wiring repair - Telstra Velocity 15Mar 08, 2016 3:00 pm Saint Mike No - Qld. I don't know the time frame you're talking about - but I'd wait for Metricon - it might be free and they should know who did it. Has it ever worked ? Definitely it has worked in the past. Yup, I'll wait for Metricon. Thanks @Saint Mike ! Re: Internal data wiring repair - Telstra Velocity 16Apr 08, 2016 11:53 am tempura Saint Mike No - Qld. I don't know the time frame you're talking about - but I'd wait for Metricon - it might be free and they should know who did it. Has it ever worked ? Definitely it has worked in the past. Yup, I'll wait for Metricon. Thanks @Saint Mike ! I would be checking the cables via a cheapie cable tester first as it might just be one pair which is loose and you might be able to just unscrew the faceplate and punch those cables using simple tools. Cable testers aren't expensive - something like this would work: http://www.ebay.com.au/itm/Telephone-Ph ... SwuYVWnMG3 Scientists have used random matrix theory to demonstrate theoretically that the neutrino mass hierarchy can be explained mathematically. When a substance is fragmented… 21 20673 If you're referring to Eufy homebase, then just put a switch between a datapoint and put the homebase elsewhere near another device in your home unless you want teh… 9 13863 DIY, Home Maintenance & Repair Hi All, Hoping someone might be be to provide some advice on my ceiling that needs repair. Photos attached, but seems like the alcove (??) is pulling away. Thanks Thomas 0 6556 |
