Browse Forums DIY, Home Maintenance & Repair Re: Remove silicone stain from white caesarstone 4Aug 27, 2015 11:54 am We use Aceton to remove silicon and is safe to use on caesarstone. Just check in a inconspicuous area first. Re: Remove silicone stain from white caesarstone 6Jan 27, 2016 7:06 pm I have used Prepsol to dissolve and remove silicone, try Dulux shop, however I have not used it on caersarstone. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Hi, planning on using the attached stone pieces in my bathroom. I want to remove stains and gloss seal. Can I get some advice on best way to remove stains and best… 0 6709 The most definitive answer to your question James is this taken from the James Hardie Axon Cladding Installation Guide - i just happen to have it… 5 3661 How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 5930 |
