Browse Forums Landscape & Garden Design Re: WREXTER'S REAR LANDSCAPING JOURNEY - Update Photos 103Aug 25, 2016 7:45 pm Build thread viewtopic.php?f=31&t=81011 Re: WREXTER'S REAR LANDSCAPING JOURNEY - Update Photos 106Aug 31, 2016 12:27 pm Building SOR with Dreamstart Homes Customised Dream Dior/Summer Sensation https://forum.homeone.com.au/viewtopic.php?f=31&t=83776 Re: WREXTER'S REAR LANDSCAPING JOURNEY - Update Photos 109Sep 09, 2016 8:19 am Our Build Thread - JG king Memphis Re: WREXTER'S REAR LANDSCAPING JOURNEY - Update Photos 116Oct 28, 2016 7:41 am i'm planning retic system for backyard, and after reading and looking at your photos motivation kicked in i have done some research, and want to know your opinion on following: 1. PVC pipe must be at least 25mm? 2. which controller brand/model would you recommend? i'm inclining towards Hunter X-Core 4 station Outdoor unit. 3. which Solenoid valve would you recommend? (looking at Hunter PGV101 or TORO 25mm EZ FLO PLUS SOLENOID Valve with flow control) 4. pop sprinkler recommendation? i'm currently looking at Hunter PGP04 Ultra or Toro 300 Series Stream Rotor Re: WREXTER'S REAR LANDSCAPING JOURNEY - Update Photos 117Nov 03, 2016 10:51 am Hi Mirz, sorry for the late reply. To answer your questions: 1. I went with 20mm, you can get higher pressure. 2. I went with a Hunter X-Core, if you can go for the 6 station, even if you think you might not need it, better to have it and not need it then not have it and need it down the track. 3. i went for the Irritol Richdel 2400MT, used them before and still going after 5 years. http://www.perthirrigation.com.au/listP ... ROL+SERIES 4. For the turf area i am using Hunter MP Rotators, cannot speak highly enough of these. very efficient sprinkler heads. And as suggested by the brochure i am using Hunter Pro-Spray PRS40 pop-ups. For garden beds, i am using Netafim drip line (3 l/h) Re: WREXTER'S REAR LANDSCAPING JOURNEY - Update Photos 118Nov 03, 2016 11:25 am Sorry for the long overdue update photos, have had slow progress with lots of rain on weekends and being away for work, almost complete now - just have to wait a couple of weeks to coat the deck. - Turf installation this weekend - Planting, retic & lighting completion the weeks after. Really really stoked at how its come together, i will post up some photos of at night with all the lights on. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: WREXTER'S REAR LANDSCAPING JOURNEY - Update Photos 119Nov 03, 2016 8:23 pm wrexter Hi Mirz, sorry for the late reply. To answer your questions: 1. I went with 20mm, you can get higher pressure. 2. I went with a Hunter X-Core, if you can go for the 6 station, even if you think you might not need it, better to have it and not need it then not have it and need it down the track. 3. i went for the Irritol Richdel 2400MT, used them before and still going after 5 years. http://www.perthirrigation.com.au/listP ... ROL+SERIES 4. For the turf area i am using Hunter MP Rotators, cannot speak highly enough of these. very efficient sprinkler heads. And as suggested by the brochure i am using Hunter Pro-Spray PRS40 pop-ups. For garden beds, i am using Netafim drip line (3 l/h) Thanks mate, that was really helpful Your backyard is looking awesome Re: WREXTER'S REAR LANDSCAPING JOURNEY - Update Photos 120Nov 10, 2016 12:16 pm Turf has been installed! Ended up using Palmetto for good shade tolerance. Hopefully i can keep it looking this green. Not to sound arrogant but loving how its all coming together, it looks awesome at night with the lighting, will take some photos at night once all the lighting is installed. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hi All, see above image. The required setback from the rear boundary in my case is 5m, as you can see the shape of the site and location of the boundary is slightly… 0 8451 Any advice on how to ensure the kit home granny flat that im thinking of buying will get council approval. The kit home companys wont release plans without a deposit and… 0 7214 |
