What info are you looking for or wanting to know?
Current prices for additional electrical items eg: double power points, 3 way switch, stair lights, bayonet points, door bell
I think it's $66 for double PowerPoint.
My build - viewtopic.php?t=87470
Browse Forums Building A New House Re: Building with Metricon 5146Apr 23, 2017 2:34 pm Our Bayside KDR Thread: viewtopic.php?f=31&t=78298 Re: Building with Metricon 5150Apr 23, 2017 10:58 pm blackcat20 Asked to add a shower niche to our ensuite and its come back as 450x450mm. I'm thinking square would look a bit strange, would I be crazy to cut the height to 400? I've been having shower niche discussion a lot of here. Having issues with M agreeing to have it taller than their standard of 350 and still have the full length of the shower wall. Seems to be getting mixed answers from M about this topic. Re: Building with Metricon 5151Apr 24, 2017 12:14 am Hi all i had my kitchen appointment on friday and it has ended in some major confusion.. Hoping others can provide some guidance.. I am confused about what laminate colour to pick for kitchen cupboards. I have picked white shimmer ceaserstone for island and bench top with black glass splashback. My wall colour is whisper white and cieling is white on white with ivort polished porcelain tiles .. I like the timber look of honey elm (as per the photo) but not sure if it fits with everything else.. Please provide some suggestion. Appreciate your help Re: Building with Metricon 5152Apr 24, 2017 12:18 am Re: Building with Metricon 5153Apr 24, 2017 3:06 am blackcat20 emmyawards blackcat20 Asked to add a shower niche to our ensuite and its come back as 450x450mm. I'm thinking square would look a bit strange, would I be crazy to cut the height to 400? I would keep the height as 450 and extend the width the whole of the shower. My build - viewtopic.php?t=87470 I think a metre long niche is overkill for a bottle of shower gel, shampoo and condition... My shower niches are 800x600 Have no idea what they will look like, but i preferred it to be wider than longer cause what could you do with a long niche? Lol Re: Building with Metricon 5154Apr 24, 2017 8:37 am DRT Hi all i had my kitchen appointment on friday and it has ended in some major confusion.. Hoping others can provide some guidance.. I am confused about what laminate colour to pick for kitchen cupboards. I have picked white shimmer ceaserstone for island and bench top with black glass splashback. My wall colour is whisper white and cieling is white on white with ivort polished porcelain tiles .. I like the timber look of honey elm (as per the photo) but not sure if it fits with everything else.. Please provide some suggestion. Appreciate your help I was going to say not sure how the honey elm would go with black splashback but it doesn't look too bad there with the dark tile. White Benchtops will add a bigger contrast to that pick though. Hmmmmm. What about a grey wood look laminate? Re: Building with Metricon 5155Apr 24, 2017 9:53 am Renman bubblynutter Renman Hi all, Anyone here installing a fireplace post handover but getting Metricon to provision space, gas and power? Did you have to nominate a model number before hand? Do they plaster the wall or cut a hole during the build? We identified the location of a post handover fireplace, but it's wood not gas. Got a plaster wall built out in the sitting room, and an isolation switch added to the electrical plan. They don't cut the plaster, the installer does that. We identified the model so the correct depth wall could be added, and so the frame could be built to allow for the heater. Cost was that of the extra plaster wall and the isolation switch. No special plasterboard was needed for our model heater or that would have had to be included too. Thanks for the info bubbly. In you plans does it look like it has a solid wall or a cut out this this? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ It is drawn as a solid wall. We built it into the room rather than outside as yours is shown, as it's an internal wall backed onto our hallway. There are photos on my thread of the sitting room projection wall at frame stage and plastered. Building the Denver by Metricon on acreage Land settlement: 24/8/15 Contracts: 8/7/16 Finance approved: 5/8/16 Council approval.....? viewtopic.php?f=31&t=79213 Re: Building with Metricon 5156Apr 24, 2017 10:08 am Renman blackcat20 Asked to add a shower niche to our ensuite and its come back as 450x450mm. I'm thinking square would look a bit strange, would I be crazy to cut the height to 400? I've been having shower niche discussion a lot of here. Having issues with M agreeing to have it taller than their standard of 350 and still have the full length of the shower wall. Seems to be getting mixed answers from M about this topic. All very strange, as I didnt specify a size and 450x450 is what they came back with. 450 wide is plenty for four bottles that week keep in the shower, and 400 high is more than enough as most bottles are under 300 so it leaves room to hit the soap pump. Re: Building with Metricon 5157Apr 25, 2017 3:33 pm Is anyone doing the decking to the alfresco after handover? If so are you asking Metricon to lower that part of the slab so when decking goes on the floor level will be flush to the inside and by how much? My build - viewtopic.php?t=87470 Re: Building with Metricon 5159Apr 25, 2017 5:03 pm emmyawards Is anyone doing the decking to the alfresco after handover? If so are you asking Metricon to lower that part of the slab so when decking goes on the floor level will be flush to the inside and by how much? My build - viewtopic.php?t=87470 I just looked at your build plans and you have 135mm step down to your outside room. So it will be able to have it flush. Re: Building with Metricon 5160Apr 25, 2017 5:04 pm Ssjo emmyawards Is anyone doing the decking to the alfresco after handover? If so are you asking Metricon to lower that part of the slab so when decking goes on the floor level will be flush to the inside and by how much? My build - viewtopic.php?t=87470 I just looked at your build plans and you have 135mm step down to your outside room. So it will be able to have it flush. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hi, First of all, thank you to this community for sharing your thoughts and opinions. We are in early days of our pre-contract stage for Metricon Doulton and we are… 0 10753 Hello All 🙂 We are planning to start our journey of construction our first home. We zeroed down on Metricon and henley homes based on design suitable for our lot and… 0 8205 We don’t live in VIC so want to know the exterior colours of Lumiere display so we can see it at the paint shop. Not building with Metricon so my request went… 0 17335 |
