Browse Forums Interior Decorating Lounge 1 Feb 07, 2015 7:04 am Hi Hope someone can help with suggestions. I am trying to move my bedroom out of the 90's I have painted three walls dulux ecru and was going to do the feature wall dulux irrigation, but it makes the room look dark and dingy and too much like it is based on the colours of a camouflage uniform. I need suggestions for another colour for the feature wall. I would like to keep the artwork which usually hangs above the bed. Thanks so much. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Note the camera has adjusted the photos so it looks like a lighter room than it actually is. Other info:-The bed and chest of drawers are staying. The window frames are to be painted vivid white. All the bedding will change. The fan light will be replaced with halogen downlights Main colours throughout Internals Ceiling /Cornice - Vivid white Walls - Dulux ecru and feature wall TBC Skirting / Architrave/Doors/Windows / Reveals / Frames -- vivid white Window Treatments - Replacing the blinds with something else as they are getting mouldy after 15 years! TBC Flooring - carpet will be replaced with similar colour to existing Lighting Dimmable Downlights and new fan without light Re: Help Ive changed my mind half way through painting! 2Feb 08, 2015 4:58 pm Some eye-catching feature wall colours are: Dulux Self-destruct Dulux Toffee Fingers Dulux Mount Eden Dulux Sea Elephant Dulux Linseed http://www.houzz.com/discussions/569172/paint-colour https://www.google.com.au/url?sa=i&rct= ... 4813412162 https://www.google.com.au/search?es_sm= ... CCAQ1QIoAQ http://www.google.com.au/imgres?imgurl= ... B8QMygBMAE Also check out this link to see linseed and other great feature wall colours as listed below. (Its an old post but still gorgeous). viewtopic.php?f=31&t=6236&start=540 Formal living & dining - Stream Entry - Linseed Family/kitchen/dining - Pink poppy Study - Domain Laundry/powder room/bathroom - Mud skipper Ensuite - Raku Master Bedroom - Custom colour from 'Covered in Paint - Newtown' Girls room - Pink parakeet Boys room - Atom blue Spare room - Essex green Re: Help Ive changed my mind half way through painting! 3Feb 12, 2015 2:18 pm Thank you sanjam, there are some nice suggestions in there. Has anyone seen an attractive green feature wall (not as dark as dulux irrigation) that teams well with Dulux ecru? Re: Help Ive changed my mind half way through painting! 4May 09, 2015 2:53 am Oh I love sanjam's suggestions! I think this would be a nice green ... http://www.houzz.com.au/photos/12296053 ... south-west Re: Help Ive changed my mind half way through painting! 5May 09, 2015 1:29 pm Given that Ecru is fairly dark for a main wall colour and you want to keep the room lighter, how about using Vivid White to contrast lighter rather than darker for the feature? That will match in with the windows, and the border in the artwork. I don't know that it's in fashon, but it seems a logical solution. I think green could be tricky with Ecru. Green feature walls are often put against white to get that clean look, or you'd be needing quite a dark green to contrast with it - and then a lot of lighting to brighten the room back up again. yep sounds good make the footing bigger to to allow for the pipe in the middle 3 7299 Hi When it rains in a particular direction water comes through the security door. It hits the main door and the bottom swells and jams. There is already a cover over the… 0 38443 |
