Browse Forums Flooring & Floor Covering Re: I work in flooring - do you have a flooring question? 561Aug 10, 2017 7:01 pm Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 563Aug 11, 2017 8:51 am Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 565Aug 13, 2017 4:28 pm Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 566Aug 22, 2017 7:57 pm Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 568Sep 13, 2017 6:31 am Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 570Sep 18, 2017 7:25 pm Hi myfavouritescar, the name rings a bell. I'll check with the boys tomorrow at work for you. How thick is the laminate 7 8 or 9 ml? Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 571Sep 20, 2017 6:19 am I had a look at the laminate yesterday.... its 12mm which is the best way to go. But we have not been able to sell the product so they took it off the shelves. Looked ok to me. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 572Sep 20, 2017 5:31 pm Michelle I had a look at the laminate yesterday.... its 12mm which is the best way to go. But we have not been able to sell the product so they took it off the shelves. Looked ok to me. Re: I work in flooring - do you have a flooring question? 573Sep 21, 2017 5:31 pm Thanks for your input Michelle! Do you know why it hasn't sold well? I've been able to price it out at $29/sqm through an online retailer. Re: I work in flooring - do you have a flooring question? 574Sep 21, 2017 6:22 pm No Idea, maybe because we have so many other products to look at as well? The colours are good. Price point maybe? Who knows.... If its a good price buy it:) Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 575Sep 21, 2017 6:35 pm Thanks! Being on such a tight budget has made its hard to just choose something and go with it. You've put my mind at ease. Re: I work in flooring - do you have a flooring question? 576Sep 21, 2017 6:53 pm Just remember NO steam mops... and put felt pads under everything!! Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 577Oct 07, 2017 10:10 am Is Quikstep the best laminate out there? We have heard varying stories from different flooring places - some say it's the best, others say there are better out there, others say that there is no difference in brands. We are looking at putting laminate upstairs in 3 bedrooms and a living area, as well as on the stairs. We also want 12mm if possible with a waterproof version. Re: I work in flooring - do you have a flooring question? 579Oct 07, 2017 2:46 pm Adelaide Girl Is Quikstep the best laminate out there? We have heard varying stories from different flooring places - some say it's the best, others say there are better out there, others say that there is no difference in brands. We are looking at putting laminate upstairs in 3 bedrooms and a living area, as well as on the stairs. We also want 12mm if possible with a waterproof version. Hi there Adelaide Girl, I prefer Quickstep.... but that's just my opinion. 12mm is the best way to go with any floating floor, less drum when you walk on it with heals. Also, because you are looking to do it upstairs, upgrade your underlay so it helps to keep that drum down from underneath. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 580Oct 18, 2017 5:34 am Why floating floors buckle - worth a read, sorry...its long. 1. Water Damage Water damage can come from several different sources. If a dishwasher has broken and leaked water everywhere, obviously replacing the dishwasher will fix the issue. However, there are other reasons why there could be water damage to your flooring.
2. Floatation & Movement Restrictions Laminate flooring is a floating floor system. The seasons, moisture, and temperature (inside and out) play important role how your flooring will perform. Sufficient expansion gaps are essential. Here are some things to look for to make sure your floor has optimum movement space:
Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Thanks mate. Yeah good points! Leaning towards Option 3 to get a bit extra space in the cabinets but not going too crazy high (and expensive). Would require a mini… 13 39735 Block of two storey townhouses requires painting on the roof. A brick parapet wall separates each unit and extends above the tiled roof. The parapet walls require sealing… 0 3503 I posted the floorplan on Houzz.com forum and got some really good ideas and advice from people there. Then we reached out to a couple of renovation companies and one… 5 10098 |
