But unfortunately last night and tonight I'm really busy.
I'll get those photos ups soon and answer your questions
No worries, it's ok appreciate your advice!
Browse Forums Flooring & Floor Covering Re: I work at Carpet Court - do you have a flooring question 502Jul 09, 2016 6:53 pm Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work at Carpet Court - do you have a flooring question 504Jul 13, 2016 6:10 am Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work at Carpet Court - do you have a flooring question 506Jul 16, 2016 6:31 pm Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work at Carpet Court - do you have a flooring question 508Jul 21, 2016 8:11 pm Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work at Carpet Court - do you have a flooring question 510Aug 17, 2016 6:59 am Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work at Carpet Court - do you have a flooring question 514Aug 31, 2016 8:25 pm Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work at Carpet Court - do you have a flooring question 515Sep 02, 2016 7:41 pm Hi Michelle....I'm looking to put down engineered oak flooring. Do you know what thickness the timber layer is in the Provincial range? Do you have any suggestions/advice/recommendations with what to look for? Do I really need at least 4mm thick wood layer? (We have young boys and the timber flooring will be in high traffic areas, including kitchen.) Thank you! Re: I work at Carpet Court - do you have a flooring question 516Sep 02, 2016 7:52 pm Darren's range of Oaks are quite nice. Its about 4 to 5 mm?? I've never really taken a lot of notice. Boards are 14mm think, the most of it is ply. (as all 14mm timber) In the Quickstep rang there is a couple of new oaks that look fantastic. To me..if they get scratched it will only enhance the appearance of the floor. Go back and read through this thread, I have photos somewhere her of it... http://www.carpetcourt.com.au/stained-o ... loors.html Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work at Carpet Court - do you have a flooring question 517Sep 03, 2016 8:47 am Hi...a question about carpets now. Should I pay attention to the weight? I'm looking at a 100% wool loop carpet. I don't really know what a good quality weight would be, and one retailer I went to said it wasn't that important. Also, is 11mm underlay the best I can get for a residential home? Thanks.. Re: I work at Carpet Court - do you have a flooring question 518Sep 03, 2016 9:58 am Hi lazandjohn, The price point will tell you the weight of the wool carpet. The more expensive it is will mean the quality is better therefore pile per content is higher. 11mm underlay is fine, we sell that with all our carpets. Website: http://www.denovoconcepts.com/wp/ Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work at Carpet Court - do you have a flooring question 519Sep 22, 2016 6:22 am On my facebook page for the next couple of weeks I will be writing about all the different types of flooring there are available. Where they are good for (areas) and where they are not. Pop over if you want to keep up if I don't manage to re-post here for a while. https://www.facebook.com/De-Novo-Concep ... 075038019/ First flooring - Timber floating floor - Tong and Groove Commonly know as engineered flooring with a small layer of timber on the top glued to a pine board backing. The best to buy is a 14mm with the 2.5 mm underlay. The thicker the better. 14mm is the thickest and provides less drum as you walk on the boards and is a much sturdier flooring than the 12mm or 8mm available on the market. This type of flooring has to be laid over a fairly level sub flooring. You need to leave at least 8 to 10mm gap around the parameter of every room. You also will need expansion joins in long rooms. If this is not done this flooring can pop up for lack of room to expand and contract and your floor will need to be taken back up and re-laid. The best look for floating floors is to take all your skirtings off, lay the floor, leave the gap, then put the skirts back on....its a nice finish. BUT, there are times that this can not be done with a renovation and the skirting s are old. In this case you leave the skirts on, lay the timber, then add Scotia around the surrounds of the skirts to cover the gap. There is a misconception that these floors don't scratch..... Wrong! These floors are only as good as how you treat them. 11 to 12 coats of polyurethane on each board, I recommend felt pads under all your furniture to avoid scratching. Here is the number 1 hint....check the bottom of your vacuum cleaner, they are the worst for scratching these floors, if your brush head is not working, put felt pads in your vac as well!!! NOTE - Absolutely NO steam mops or wet mopping to be applied to any floating floor at all! These floors are water resistant, to a point, NOT water proof. Any spills, no problem, just wipe them up straight away. "This is most important" - This is NOT a floor I recommend for rentals, avoid it!! I can recommend something better. You want a solid timber floor layer, I can provide you with one of the best. Just let me know. http://www.quick-step.com.au/timber/readyflor Ok, any questions? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Website: http://www.denovoconcepts.com/wp/ Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work at Carpet Court - do you have a flooring question 520Sep 27, 2016 6:52 am October specials - Book now so you don't miss out. email - michelle@denovovoncepts.com Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Website: http://www.denovoconcepts.com/wp/ Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Thanks mate. Yeah good points! Leaning towards Option 3 to get a bit extra space in the cabinets but not going too crazy high (and expensive). Would require a mini… 13 39696 Block of two storey townhouses requires painting on the roof. A brick parapet wall separates each unit and extends above the tiled roof. The parapet walls require sealing… 0 3501 I posted the floorplan on Houzz.com forum and got some really good ideas and advice from people there. Then we reached out to a couple of renovation companies and one… 5 10093 |
