Browse Forums Owner Builder Forum Re: Studio (fancy shed) build 255Apr 22, 2015 4:02 pm Our Build Thread: The "Extended" Marina by Visionone Homes Our Inspirations: Frank Lloyd Wright | Houzz Re: Studio (fancy shed) build 257May 09, 2015 8:47 pm Winter approaches and so we are now constructing a slow combustion fireplace for our heating needs. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Still lots of work to go. Not quite sure what the end product will look like as we are designing and building it from whatever materials we can scrounge from our junk pile. Re: Studio (fancy shed) build 258May 11, 2015 12:45 am Still more hours to go, but it is taking shape. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The chamber on top should allow us to recover lots of extra heat from the exhaust gasses before they go up the chimney. Still got to find something to make the door and latch, flue fitting, damper and air inlet. The cost so far has just been welding consumables..... and time and effort. I would suggest you simply go and talk to council about your proposal, most councils are getting onboard with ancillary dwellings. There is no benefit in keeping it… 1 4123 Is it possible to render an old corrugated iron shed.I have heard that it can be done if it is covered with chicken wire first.Not sure of the ratio of the render mix and… 0 4897 Thanks. Yeh ideally that would have been good, but have progressed too far now. Hoping some well placed internal walls fixed up into the battens will provide some… 2 5412 |
