Browse Forums Heating, Cooling & Insulation Re: How's your air conditioning coping in the heat? 23Jan 29, 2014 3:04 pm The problem with running an aircon at 26 degrees is that is too warm to sleep comfortably IMHO. 24 is ok I reckon. But each to their own, I am extremely uncomfortable in the heat but will happily live in a house at 16 degrees in the winter. But other members of our family are the opposite. Hate the cold and would happily live in Darwin. Re: How's your air conditioning coping in the heat? 24Jan 29, 2014 7:00 pm When I say 26 degrees that day time temp. Agree it needs to be 24 at night. Which ok. The ac works much better at night. It would be cheaper to run ac at 24 at night that 26 during the day. Re: How's your air conditioning coping in the heat? 25Jan 29, 2014 8:17 pm Well just checked Solar choice. At a price of just under $8000 for solar power to be installed, it may have to wait a while. This was not a premium install either. That's a long time to come close to break even point. Apart from that, we have checked our bills along with others nearby, and they are not so out of the ordinary. Around here power just seems to be expensive. Settlement 1/2/12 New Shed 23/3/12 Slab poured 27/3/12 Frame complete 4/5/12 Roof complete 1/6/12 LOCKUP 29/6/12 Our new build blog http://kareenhillsownerbuild.blogspot.com/ Re: How's your air conditioning coping in the heat? 26Jan 30, 2014 6:10 am I have quotes around $6k for a 5kw system using premium solar-edge components, hopefully someone comes back with a more reasonable quote for you... we have quotes under $1 per watt for my work (not that they are keen on such a long pay down either) Slooowwwwly getting a Manhatten 35 in Middleton Grange Re: How's your air conditioning coping in the heat? 27Feb 02, 2014 10:24 pm Not to mention running at 26 deg means the aircon would basically not come on. The house only gets between 26-7 on 40 deg plus days!! Settlement 1/2/12 New Shed 23/3/12 Slab poured 27/3/12 Frame complete 4/5/12 Roof complete 1/6/12 LOCKUP 29/6/12 Our new build blog http://kareenhillsownerbuild.blogspot.com/ Re: How's your air conditioning coping in the heat? 28Feb 03, 2014 7:04 am delatite13 Not to mention running at 26 deg means the aircon would basically not come on. The house only gets between 26-7 on 40 deg plus days!! A bit ironic that given you have gone to a lot of trouble to make you house as energy effecient as possible but then run ac down to 21. I challenge you to run it at 25. Does your system have inverter technology or is it basic on off. Note this is a comman theme I see in energy effecient homes. People need to start under dimension ing their ac in these homes for better performance. Re: How's your air conditioning coping in the heat? 29Feb 03, 2014 7:20 am B STAR People need to start under dimension ing their ac in these homes for better performance. OR start putting large solar array's on Slooowwwwly getting a Manhatten 35 in Middleton Grange Re: How's your air conditioning coping in the heat? 30Feb 03, 2014 7:41 am MR2 B STAR People need to start under dimension ing their ac in these homes for better performance. OR start putting large solar array's on They can do that. However it takes a lot of energy to produce solar panels. Its much easier to change user habits. Re: How's your air conditioning coping in the heat? 31Feb 03, 2014 7:44 am it's even more efficient to increase the insulation/shading over the house and not use your aircon at all but I like solar, as it's one of those things that should offset usage for 30+ years Slooowwwwly getting a Manhatten 35 in Middleton Grange Re: How's your air conditioning coping in the heat? 32Feb 03, 2014 11:58 am MR2 - As said, we would love to have solar power, however financial issues preclude this. Since some are such proponents of solar perhaps they can finance the deal for us. We would be very appreciative!! Or do you know of an supplier/installer that is reasonable and won't charge the earth to travel to N/E Vic. BStar - 21 degrees?? As the ad says "Better go to Specsavers". Read the post. This is the aircon we have. http://www.actronair.com.au/espplus I am unaware of any other system that has the same capabilities. Settlement 1/2/12 New Shed 23/3/12 Slab poured 27/3/12 Frame complete 4/5/12 Roof complete 1/6/12 LOCKUP 29/6/12 Our new build blog http://kareenhillsownerbuild.blogspot.com/ Re: How's your air conditioning coping in the heat? 33Feb 03, 2014 12:50 pm delatite13 MR2 - As said, we would love to have solar power, however financial issues preclude this. Since some are such proponents of solar perhaps they can finance the deal for us. We would be very appreciative!! Or do you know of an supplier/installer that is reasonable and won't charge the earth to travel to N/E Vic. BStar - 21 degrees?? As the ad says "Better go to Specsavers". Read the post. This is the aircon we have. http://www.actronair.com.au/espplus I am unaware of any other system that has the same capabilities. Your right very hard to read off an s4. Not sure if new glasses will be good enough. What r u running it at to be hit with though sort of electrity bills. Re: How's your air conditioning coping in the heat? 34Feb 18, 2014 10:49 pm I remember last week we visited a friends house, her Ac is on and at the same time her humidifier,the living room as well as the dining is airconditioned. I wonder why she has to turn on the humidifier, what for? the AC is cool. Re: How's your air conditioning coping in the heat? 35Feb 19, 2014 5:54 am I'm assuming she has an issue like dry skin or something.. Aircon takes the moisture out of the air, humidifier (obviously) put's it back in Slooowwwwly getting a Manhatten 35 in Middleton Grange Re: How's your air conditioning coping in the heat? 36Feb 21, 2014 3:52 pm MR2 I'm assuming she has an issue like dry skin or something.. Aircon takes the moisture out of the air, humidifier (obviously) put's it back in Ohh very well said, that is why thanks! too dry air causes a lot of allergies, and that friend of ours is sensitive to allergens. In my case i use humidifier if its really dry air/weather. Re: How's your air conditioning coping in the heat? 37Mar 01, 2014 8:12 am Evaporative 26sq home.. basicly its just running on idle set at 28c and easily maintaining it on a 42c day (could make it cooler). The hourly running cost is around 15c-20c per hour max rate would be 40c. Anybody know any good and reasonably priced Air conditioning contractors/companies that could install a ducted air conditioning system in the Central Coast NSW for a small… 0 8991 There may be answers here but can't find anything. I have a closed in veranda, four windows. North facing, just had sunblock blinds installed. A bit cooler (actually… 0 2975 How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 5928 |
