Browse Forums Heating, Cooling & Insulation Re: add on air conditioner to ducted heating? 3Jan 16, 2014 3:47 pm Build Permit-17/12/13 Earthworks-13/1/14 Slab-30/1/14 Frame-10/2/14 Lock Up-7/3/14 Fixing Stage Complete-20/3/14 New Home Presentation-6/5/14 Moved in 17/5/14! Blog: http://dandesbuild.blogspot.com.au Re: add on air conditioner to ducted heating? 6Jan 17, 2014 5:03 pm Build Permit-17/12/13 Earthworks-13/1/14 Slab-30/1/14 Frame-10/2/14 Lock Up-7/3/14 Fixing Stage Complete-20/3/14 New Home Presentation-6/5/14 Moved in 17/5/14! Blog: http://dandesbuild.blogspot.com.au Re: add on air conditioner to ducted heating? 10Jan 24, 2014 1:02 pm B STAR hi coolbri is it possible that they quoted you on the reverse cycle unit. I thought this was the only one in their range that had inverter technology. what was the model number they quoted. It would be great if they did have an add on cooler that had inverter technology. It would be even greater. Hi B STAR The new range of add on coolers have inverter technology ( 18 and 22kw systems dont ) The model number they quoted me on is the 15kw system DONSC15Z7 What do you think of the price? Site Cut 8/04/12 Slab 13/04/12 Frame 18/04/12 Roof 07/05/12 Lock Up 06/06/12 Keys 30/08/12 Re: add on air conditioner to ducted heating? 11Jan 24, 2014 1:21 pm the product sounds good. I spent around 12K for a whole new system (not the inverter type) around 5 years back. Its a shame you cant use the same ducts as this would save you a couple of thousand. to put things in prospective it will cost 4 K fo the cooling units on there own. Plus the install plus the new duct work. Re: add on air conditioner to ducted heating? 12Jan 24, 2014 3:22 pm I was quoted $7095 for the 13kw Add on Brivis cooling - inverter for 2 zones. I already upgraded the ducts within the heating portion so I think your price is good. The model I have quoted is DINXV13-7. Build Permit-17/12/13 Earthworks-13/1/14 Slab-30/1/14 Frame-10/2/14 Lock Up-7/3/14 Fixing Stage Complete-20/3/14 New Home Presentation-6/5/14 Moved in 17/5/14! Blog: http://dandesbuild.blogspot.com.au Re: add on air conditioner to ducted heating? 13Jan 24, 2014 3:43 pm Thanks guys Im happy with the price so I booked it in for 3rd Feb Will let you know how it all goes Site Cut 8/04/12 Slab 13/04/12 Frame 18/04/12 Roof 07/05/12 Lock Up 06/06/12 Keys 30/08/12 Re: add on air conditioner to ducted heating? 14Feb 09, 2014 1:26 pm coobri Thanks guys Im happy with the price so I booked it in for 3rd Feb Will let you know how it all goes Hi Guys The install of the unit went without any problems the guys were there all day I must say it has done an excellent job keeping the house cool this week have had it set at 23deg and its doing it easy with the temp being upto 40 outside Site Cut 8/04/12 Slab 13/04/12 Frame 18/04/12 Roof 07/05/12 Lock Up 06/06/12 Keys 30/08/12 Re: add on air conditioner to ducted heating? 18Feb 15, 2014 8:45 am B STAR so that means that it always stays on and doesn't shut off??? I hate it when mine shuts off. The fan in the roof shuts off but I think the system outside keeps going Site Cut 8/04/12 Slab 13/04/12 Frame 18/04/12 Roof 07/05/12 Lock Up 06/06/12 Keys 30/08/12 Hi all, sorting out the ducted air con for a 350sqm double story house. Does this placement sound reasonable to you? Also, I plan to have 6 zones I think. Living room… 0 0 Hi all, sorting out the ducted air con for a 350sqm double story house. I think i plan to have 6 zones I think. Living room (mainly for entertainment so not used often),… 0 0 0 6304 |
