joey_smith1986
Our original completion date in the contract was Jan 5th.
Joey (8 Dunsyre Av.)
Still ages to go then
Browse Forums Building A New House Re: Building at Northlakes Estate- Cameron park 2944Apr 21, 2016 11:26 pm https://forum.homeone.com.au/viewtopic.php?f=31&t=80908 Re: Building at Northlakes Estate- Cameron park 2946Apr 21, 2016 11:33 pm https://forum.homeone.com.au/viewtopic.php?f=31&t=80908 Re: Building at Northlakes Estate- Cameron park 2948Apr 21, 2016 11:38 pm https://forum.homeone.com.au/viewtopic.php?f=31&t=80908 Re: Building at Northlakes Estate- Cameron park 2951Apr 26, 2016 9:18 pm https://forum.homeone.com.au/viewtopic.php?f=31&t=80908 Re: Building at Northlakes Estate- Cameron park 2953Apr 26, 2016 11:09 pm https://forum.homeone.com.au/viewtopic.php?f=31&t=80908 Re: Building at Northlakes Estate- Cameron park 2955Apr 26, 2016 11:29 pm https://forum.homeone.com.au/viewtopic.php?f=31&t=80908 Re: Building at Northlakes Estate- Cameron park 2956Apr 26, 2016 11:30 pm Optus for NBN, but still with Telstra for our phones. Re: Building at Northlakes Estate- Cameron park 2957Apr 26, 2016 11:34 pm powerfamilybuild Dunsyre100 We are running a very similar setup and 25 is easily enough to run multi devices even though I upgraded to 50mbps just to cover those intense periods. Not sure if 50gb will be enough though but it would be close to the mark. Who did you guys go through? Tossing up if its best to go through one provider for absolutely everything or split it up viewtopic.php?t=80908 Skymesh 50mbps plan. Unmetered Netflix. This was the best deal for me. You will probably need more than 50gb peak time. Daniel Building estimator at Ford Homes Building designer after hours: Whitehaus Design & Drafting Re: Building at Northlakes Estate- Cameron park 2958Apr 26, 2016 11:37 pm powerfamilybuild Dunsyre100 We are running a very similar setup and 25 is easily enough to run multi devices even though I upgraded to 50mbps just to cover those intense periods. Not sure if 50gb will be enough though but it would be close to the mark. Who did you guys go through? Tossing up if its best to go through one provider for absolutely everything or split it up viewtopic.php?t=80908 And make sure you get at least an AC1900 wireless router otherwise it would be like putting a kombi on the autobahn. You don't need a modem. Just a wireless router. Daniel Building estimator at Ford Homes Building designer after hours: Whitehaus Design & Drafting Re: Building at Northlakes Estate- Cameron park 2960Apr 27, 2016 9:42 am KLB Do you know your roof sarking is on? I’m curious about how you went with this. We are planning a KDRB and considering Plantation Homes as a builder. I’m aware that after the demolition another soil test… 1 6326 |
