Browse Forums Building A New House Re: LOOSE LAY KARNDEAN - update from old thread 142Sep 24, 2013 11:45 pm Recently moved to a 60's home in need of some improvement! http://s797.photobucket.com/user/leenii ... ch%20House Old house: http://s797.photobucket.com/albums/yy25 ... loo/House/ Re: LOOSE LAY KARNDEAN - update from old thread 157Jun 04, 2014 10:05 pm water yes l have them in all wet areas no problems and you don't have to sand them back Re: LOOSE LAY KARNDEAN - update from old thread 158Jun 04, 2014 10:06 pm Looselay might be easier to look then timber, but you can't sand looselay back and reseal. This floor is certainly not foolproof. If you're not careful it will scratch and look sad. We just had our vinyl planks stripped and resealed (kind of like timber but not haha) and it made no difference to the visibility of the scratches at all Re: LOOSE LAY KARNDEAN - update from old thread 159Jun 04, 2014 10:10 pm ment they are better imo because you don't have to sand them back like solid timber.sanding is a pain with dust even with a bag on sander ,then you need to stay off floor when you reseal.SB did Karndean not inform you about dogs (re scratches)l was told treat it like solid timber. Re: LOOSE LAY KARNDEAN - update from old thread 160Jun 05, 2014 10:33 am pattycake4 ment they are better imo because you don't have to sand them back like solid timber.sanding is a pain with dust even with a bag on sander ,then you need to stay off floor when you reseal.SB did Karndean not inform you about dogs (re scratches)l was told treat it like solid timber. I have a cat, but am hoping to get a dog in the future (hubby will have a raised eyebrow when he reads this ) - We are getting Country Oak, so hopefully scratches and marks won't be as visible because the floor is not too dark ... A Sabco spin mop, minimal moisture, not very regularly. I was told these hybrids are water resistant 🤷♀️ 2 7640 Hi, Apologies - I know there is plenty out there on this but struggling to put together the puzzle. We're planning our garage/external laundry to master bedroom and… 0 11117 Is it possible to render an old corrugated iron shed.I have heard that it can be done if it is covered with chicken wire first.Not sure of the ratio of the render mix and… 0 4896 |
