Browse Forums Paving & Concreting 1 Nov 07, 2012 3:17 pm Called the tiler, actually three. One came with his laser to measure because he noticed a hump in the middle of the slab. 22.5m2 alfresco slab, worst spots are 25mm too high. Also fall goes to house not away. Steps are cracking and not regulation. Tiles were supposed to be flush with sliding door but slab got poured too high. Have had advise to break it up and re pour the slab. Scaryfing and grinding will take way too long and cost too much. The builder is taking us to VCAT because he wants his last 5%!!!!!!!!!!!!!!!!!!Work that one out. Does $8,000 sound right for skip, removal and new slab via pump (no access anymore)? Re: Left with uneven alfresco slab for new house 2Jan 03, 2013 11:47 pm How did you go? Where you are coming from is where you are going to... Re: Left with uneven alfresco slab for new house 3Jan 06, 2013 8:59 am Still here with the same problem. VCAT mediation in Feb now. I doubt that anything will change, we owe him money but with our report and defects he owes us more than double that now. Just a waste of time and money! When this is over ( don't know how much VCAT is going to cost) we will get it cut into squares and jack hammered off. Thanks. Re: Left with uneven alfresco slab for new house 4Jan 06, 2013 9:04 am no point in grinding it? Where you are coming from is where you are going to... Re: Left with uneven alfresco slab for new house 5Jan 06, 2013 9:06 am It is going to be tiled so no polishing, can't cost more than 2500 to grind. Where you are coming from is where you are going to... Re: Left with uneven alfresco slab for new house 6Mar 11, 2013 8:51 pm Went to mediation at VCAT, builder wanted his last 5%, we held it back because some things weren't finished and defects not fixed. We had to hire a lawyer & barrister to defend ourselves ($6,000 +) and the result was 0-0. The builder walks away and we are left to fix the slab and other defects. I am so happy over this result, I just wanted the builder to p*** off . Papers were drawn to release him from any further liability. It cracks me up, you can pinch a picnic bar from the 7 Eleven and get arrested but tradies and builders owe work and money, nothing! First time building. this triangular part (marked in red) behind my two bedrooms does not have external wall bec of Alfreco roof… 0 696 I hope this help you newhome_24, AS3958.1 is the Ceramic Tile Installation Standard. It specifies the tolerances for the installation of tiles. The tile supplier is… 1 7644 Old Home Restoration / Renovation Hi, just discovered all these junks left behind under the floor. Could any of these be asbestos? Best to leave as it is or clean up? Thank you for your thoughts 0 9472 |
